replacing fuel sending unit?
Old Dec 5, 2006 | 01:10 PM
markhaas's Avatar
markhaas
Stage III
Default replacing fuel sending unit?
I have an 04 Softail standard, FI, and the fuel gauge is not working properly. I recently ran out of gas and found out that with the key on the gauge will rise to 3/4, with key off it goes back to empty. Is this a sender problem? If so where is it and how hard is it to replace? Thanks
Old Dec 5, 2006 | 01:19 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: replacing fuel sending unit?
If it says that you have 3/4 tank and its empty then it probably does have a problem. If its just going to empty because you have the ignition off that's normal. At least that's the way mine works.
The sending unit is mounted inside the top of the tank under the dash panel. The manual has a long writeup on how to get it out, and I suggest you get hold of a copy of it as it looks like you have to dismantle nearly everything in there to get at it.
Old Dec 5, 2006 | 02:32 PM
monkyman's Avatar
monkyman
I just swapped out tanks and let me tell you, for me it was a royal pain in the a$$ to swap pump/sending unit. It could just be my experiance, but it was not fun. The manual is ok for pictures, but really does not tell you everything you want to know. The float sits between the tank tunnel and the tube for the gauge wire. Yours could be hitting either and sticking it up. You can't see crap when installing it, and all the time your worried about scratching your tank.
Sorry for the rant, but you can do it, it just takes time and patiance.
Good Luck.
Old Dec 5, 2006 | 02:59 PM
LRonHoover's Avatar
LRonHoover
Trip meter, trip meter, trip meter.
The last thing I'm going to rely on is a cheap gas gage.
Old Dec 5, 2006 | 03:29 PM
Denbo's Avatar
Denbo
I have taken mine off twice already and it is pretty easy.It pops right out with a little pressure and I just snip the two wires that run under the tank and pull it thru.You can't on my bike disconnect it from connector because the ends won't fit thru the little tube that runs thru the tank.My gage has been pretty reliable so far but I do use my trip odometer also as a back up especially on longer trips.
Old Dec 5, 2006 | 04:28 PM
cwsharp's Avatar
cwsharp
Umm... it isn't a Delphi connector that you can remove the pins from (with a Delphi pick) and just pull the wires through the tube?
C#
Old Dec 5, 2006 | 04:32 PM
Denbo's Avatar
Denbo
Mine wouldn't fit thru the tube so I just snipped the wires and reconnected them.But you are correct and they are simple to un-do.My painted tanks had too much paint in them to pull thru.
Old Dec 5, 2006 | 04:52 PM
brian1's Avatar
brian1
From what you describe, it sounds like the float is hung up inside the tank. It's a common problem on these bikes. You need to remove the end of the rod where it goes through the float (make it shorter) so it doesn't hang up.
Old Dec 5, 2006 | 05:00 PM
Denbo's Avatar
Denbo
Good to know,thanks for posting the advice Brian1
Old Dec 7, 2006 | 12:50 AM
markhaas's Avatar
markhaas
Stage III
OK Thanks. Retired in 2003 from Army also.
firebugmel
Nov 2, 2017 03:20 PM
eskimo09
Jun 19, 2017 05:28 PM
WVICEMAN
EVO
Jan 16, 2013 03:13 PM
BungoBill
EVO
Jul 23, 2010 02:48 PM
Skyglide
Exhaust System Topics
Nov 23, 2009 10:43 PM
