Brake Pedal query
Old Dec 19, 2011 | 11:19 AM
Sgt_Jim's Avatar
Sgt_Jim
Default Brake Pedal query
First off, I like the word Query..i don't think it's used enough.
Secondly, I'm getting my brake pedal powdercoated wrinkle black. I have it painted with the truck-bed liner trick, but it just didn't come out evenly and it's already flaking in places. So i'm gonna try the PC route.. None of this is important.
What's important is this.. There's a small plastic piece (not really a bearing, just a plastic tube) inside of where the pedal slips on to the mount on the frame.. does this plastic piece come out? Or do you think it'll handle the 450* baking temperature? I should probably just call the guy and ask..huh?
Old Dec 19, 2011 | 12:29 PM
CB1's Avatar
CB1
yeah I would call. Probably should come out before hand. My guess would be that at 450 degrees it's gaonna come out anyways, just not how you may want it too.
But I'd be intererested to know the answer to your query.
Old Dec 19, 2011 | 01:03 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I am sure you can get it out with a press. Nice QUERY. Good word.
Drew
Old Dec 19, 2011 | 01:10 PM
Sgt_Jim's Avatar
Sgt_Jim
After some whacking and smacking.. there's actually 2 small plastic pieces in there, and they come out with a clamp, a flathead screwdriver, and a bigass hammer.. yeah. so i guess that answers my question. haha
Old Dec 19, 2011 | 03:55 PM
olongapo1's Avatar
olongapo1
Sgt,
The 2 piece plastic sleeve will Not hold up to PC baking. Remove the sleeves and re-install after. If you damage them, they can be purchased from Harley cheaply.
Old Dec 19, 2011 | 04:03 PM
Misbehaven's Avatar
Misbehaven
Just remember that if they get any pc in the hole you will have to remove it to replace the plastic bushings.
Old Dec 19, 2011 | 04:23 PM
Sgt_Jim's Avatar
Sgt_Jim
I managed to get the plastic pieces out, no problemo. and ill probably have to scrape out the PC from inside there anyways.. thanks all
Old Dec 19, 2011 | 08:08 PM
cwsharp's Avatar
cwsharp
they are just bushings... you can get a replacement from your friendly stealer.
Old Dec 19, 2011 | 08:35 PM
FroggyFatBoy's Avatar
FroggyFatBoy
when we did powdercoating to our sons 1/4 midget(think sprint car without wing) we would install old bolts in holes and tubes that we didn't want filled with powdercoat. that stuff is hard as a rock and a bitch to cut or grind down or out.
Old Dec 19, 2011 | 08:42 PM
Sgt_Jim's Avatar
Sgt_Jim
yeah i experienced that with the first round of powdercoating.. luckily, though, my neighbor has a full set of dies and taps, so getting the coating out is as easy as running a tap through the threads
DustinM
Apr 17, 2015 08:04 AM
wormtail
Mar 14, 2014 11:39 AM
chromedome
May 25, 2009 12:21 AM
GzrGlide
May 6, 2008 09:07 PM
Idiot
Nov 25, 2007 12:07 PM
