Question-Does anyone know which air cleaner does not extend out any more than the stock A/C. I've been reading about some that are out at least an inch from the stock.
I don't believe either the SE stage 1 or AN big sucker 1 stick out, both can use stock football cover. I could be wrong as I haven't installed my AN yet.
RE: 07 Air Cleaner
The Screamin' Eagle intakes extend out ~1" further than stock. This is probably a requirement to achieve the increased air flow/performance provided by these intakes. It's true you can use the stock cover, but it's also true it will no longer be in the stock location.
I have the Big Sucker installed on my bike. I believe it is actually closer to the bike than stock. My buddy has the SE AC and it sticks out further than mine. Here's a pic.
cycle visions just introduced a new air cleaner that increases flow and does not stick out any further than stock. Actaully looks like it is closer. Uses K&N filter. Go to their website www.cyclevisions.com.
