Aftermarket frame Question
Old Jan 5, 2012 | 11:29 AM
metalb00's Avatar
metalb00
Default Aftermarket frame Question
So i came into a paughco 60's style fl swingarm frame p/n R147T for free and im new to the harley world, this is a soft tail frame? its not a rigid i know that for sure and it takes an evo fxr drivetrain but thats about where it ends
Old Jan 5, 2012 | 11:31 AM
Stiggy's Avatar
Stiggy
If ever there was a time to see a picture of what you're talking about....Gotta' camera?
Old Jan 5, 2012 | 01:08 PM
metalb00's Avatar
metalb00
http://www.google.com/url?sa=t&rct=j...e5GJkNdDwzJ5gw
is the pic from paughcos site
Old Jan 5, 2012 | 01:11 PM
metalb00's Avatar
metalb00
i got the swing arm, oil tank and tank mount figure now i have to build it into something
Old Jan 5, 2012 | 05:33 PM
Stiggy's Avatar
Stiggy
Thanks for the pics. It is a 60's '4 speed' STYLE frame modified to accept the rubber mount FXR/FLT components that were introduced in 1980 (FLT) and 1982 (FXR) respectively to reduce vibration.
The Softail reference refers only to the oil tank, a "wrap around" normally not wrapped around the center post on an FXR/FLT but is on all softail models, and will sit just under the seat, visible from both sides. Thus the Softail style description.
Basically it's a Paughco designed custom swingarm frame utilizing rubber mount technology with a little bit of Softail style.This frame will accept conventional visible rear shocks.
Depending on your state, it will end up being a Home Built or Special Construction motorcycle. It will not be titled a Harley regardless of who's power plant you choose.
Good Luck!
Old Jan 6, 2012 | 11:26 AM
metalb00's Avatar
metalb00
yea it will be some sort of custom on the title, but i was basically wondering if i could find a harley model or models that match this somewhat.
Old Jan 6, 2012 | 05:40 PM
Stiggy's Avatar
Stiggy
For building purposes, consider it an FXR, 82 to 94 ( except for the oil tank of course.)
Old Jan 7, 2012 | 08:16 AM
metalb00's Avatar
metalb00
thanks, that's infinitely helpful!!
chaz mcnasty
Dec 5, 2013 01:26 AM
warrconn
Shovelhead
Oct 16, 2010 09:40 PM
Scgoobertn
Aug 25, 2009 06:44 AM
brogotee
Feb 8, 2008 01:58 PM
xcaret
Shovelhead
Apr 6, 2007 07:26 PM
