Heritage Softail Lowered?
Old Feb 23, 2012 | 09:57 PM
neilgehrke's Avatar
neilgehrke
You'll know if its lowered because it will look cool. :-)
Old Feb 23, 2012 | 10:42 PM
Mathis's Avatar
Mathis
Originally Posted by mjrfd99
Bone stock here and it scrapes all the time.
Same here. I can scrape them at will. I've even scraped the engine guard twice. Talk about scary!
Old Feb 24, 2012 | 12:30 AM
jlasoftail's Avatar
jlasoftail
I scrape mine all the time. Usually around a slower tight turn, but the odd time i'll do it at speed. just means you're getting everything you can out of your turns
Old Feb 24, 2012 | 08:27 AM
Hippiebeads's Avatar
Hippiebeads
I am a very conservative rider and I scrape mine all the time.First couple times it scares you but you will get use to it.
Old Mar 6, 2012 | 08:34 AM
Newfoundlandsoftail's Avatar
Newfoundlandsoftail
I have scraped mine as well!
Old Mar 6, 2012 | 09:45 AM
hdgzr's Avatar
hdgzr
Mine's stock height and I scrape once in a while also. I call it "making it a custom"....
Old Sep 28, 2013 | 10:31 AM
MICHALISLARNACA's Avatar
MICHALISLARNACA
My advice to all riders who lower bikes. Do it the correct way. Do not just slam the rear end down. The geometry is screwed up which throughs the bike off. If you are going to lower it you must:
Change front springs and use heavier oil
Change rear inner spring shocks to higher thickness and coils
Change the angle of the kick stand
Then you need to remove engine guards and raise floor boards
Old Sep 28, 2013 | 10:53 AM
NDBadlands4-2's Avatar
NDBadlands4-2
To see if the rear has been lowered there will usually be a screw tht lengthens the shocks. In a Softail you ut longer shocks on to make the bike lower. Adjust it to make the shocks shorter and you may gain some lean angle. My Heritage is not lowered, but I scrape all the time. I do prefer I to the Night Train that I used to have. On that bike it was your boot heels that dragged in the corner. Now that will get your attention.
flyguy9631
Jul 12, 2013 07:29 AM
08FLSTN
Oct 15, 2012 02:20 PM
Nellybelle
Nov 6, 2008 06:16 PM
Hidalgo
Aug 16, 2008 01:00 PM
big cahuna
Motorcycles For Sale
Aug 30, 2007 03:07 PM
