Fuel Crossover Line removal?
Old Mar 6, 2012 | 03:42 PM
theidbreder's Avatar
theidbreder
I got impatient with my tank removal and had 3/4 a tank. Like HRK123 said I used small vise grips to keep from spilling too much. I also had a 5 gal gas can with two 1/2" X 24" rubber hoses feeding into it. From there I put the cut ends into the rubber hoses and let the grips go to drain it into the gas can. Had a little leakage but not too bad and I saved most of the gas. lol
Old Mar 6, 2012 | 03:48 PM
wadejesu's Avatar
wadejesu
Default Fuel line
You would think after all these years, HD would get rid of that stupid hose somehow. It is such a pain. On one of my Dyna's I installed a quick disconnect that blocked flow once disconnected it worked great never spilled a drop ,however with the spigots being so close and quick connect so long it looked like ****, so I went back to vise grips and hose pinchers. At least HD fixed the switch pods on the handle bars, all the wiring is in the bottom and top comes off easy
Old Jan 23, 2014 | 07:54 PM
dmckay1972's Avatar
dmckay1972
Stage I
I just unbolted my tank on my Blackline and made a huge mistake of undoing the bolt where the quick disconnect is on the tank (before I figured out the disconnect). Huge! Has spill. Now that that's all cleaned up I'll remove the crossover with the vice grip method given here, but how do I thread the upper portion of the disconnect back into the tank? It's connected to what I can only assume is the fuel pump. When I try and thread it in, I'm twisting something inside the tank. Anyone ever done something this brainless?
Old Jan 23, 2014 | 08:13 PM
jreichart's Avatar
jreichart
You'll probably have to pull the fuel pump assembly from the tank, disconnect the supply hose, then reconnect the quick disconnect fitting. Before you do this, stop by the dealer and get a few of the crimp style hose clamps to reattach to the fuel pump assembly. If you dont have the crimp tool, a set of tile nippers from the hardware store will work in a pinch. Depending on your mileage, it might also be a good idea to replace the fuel pump and the other in-tank hoses (the dealer sells a kit) while you have the fuel pump out of the tank. They are known to develop pinholes. Hardest part is removing and reinstalling the pump assembly, but plenty of videos on YouTube to help out. Good luck!
Old Jan 24, 2014 | 12:37 AM
CagelessRoy's Avatar
CagelessRoy
I really wish I would have found this thread before last Saturday! I was doing the 1.5" tank lift and the crossover only allowed about a half inch lift. Using dikes I finally mauled the first hose clamp enough to slip an end of the hose off the nipple. Then surprise! Siphoning the tank did not remove all the gas! So I'm trying to plug the hose and the nipple with one hand while grabbing my siphoning hose, place it over the nipple, good, right side drains about the time my fingers start to cramp. Then no funnel within reach so just held the siphoning hose to the crossover hose end-to-end. Managed to totally soak the microfiber towel I had placed over the cylinder head, but only a few tablespoons of gas made it to the floor. Y'alls ways sounds a lot easier!
Bryce05
EVO
Jan 15, 2018 05:04 PM
16VAFXDL
Feb 13, 2011 08:49 AM
MZBuckeye
Aug 20, 2009 01:08 PM
Grunter
Aug 10, 2008 12:10 PM
ggibson
Feb 20, 2008 09:25 AM
