Aaarrgh! Crappy torx screw stripped!
Old Mar 12, 2012 | 01:46 PM
Wabbit's Avatar
Wabbit
Anyone know for sure what the official torque is for the derby cover screws on a 2011 Fatboy lo?
Old Mar 12, 2012 | 01:51 PM
cromagnon's Avatar
cromagnon
Anytime working with primary cover, make sure not to over torque. Other than seal wearing out, the primary cover is the most likely place to develop leaks.
Old Mar 12, 2012 | 02:01 PM
Skeezmachine's Avatar
Skeezmachine
Originally Posted by Wabbit
This idea was suggested to me: cut off the bolt head (it wasn't explained how...) and remove the derby cover, then use vice grips on the nub of the bolt to turn it out.
Has anyone used one of these things where you drill into the bolt and use an extracter? I bought one but I hesitate to use it. No instructions, for one, so I hope it's pretty self explanatory.
I've used one and like yours, it didn't come with instructions but its really simple. Mine works by first drilling into the head of the stripped bolt to give the hole a little depth. Then I install the extractor which is a bit that fits into my drill just like any other drill bit but is designed to grip going in reverse. As you turn the extractor into the head of the bolt it cuts and grips into the bolt and should turn it.
I've use the other method you mentioned on stripped screws and bolts also. Basically I take drill bits and and start drilling into the head of the stripped screw. The idea is not to drill deeper than the head of the screw. Instead you keep changing out drill bits for bigger ones. The goal being that you reach a drill bit size big enough to just drill away the head of the screw, allowing you to just slide the cover off the stem which will still be threaded into your primary cover.
A note: I have never had to do this on my motorcycle. I imagine the margins for error are a lot smaller since often times you gotta worry about slipping and scratching up a part or whatever.
Wish I could offer other advice. I don't think the screws that Harley uses on the derby cover are cheap and would blame the issue more on someone improperly installing one. I have never had a problem with stripping any screws or bolts on my bike (knock on wood). I have had it since new and have done all manner of wrenching on it including all my primary oil changes and clutch adjustments.
As soon as I could afford it I bought a set of torque wrenches to cover all the applications of my bike when I am installing parts back on.
Good luck getting that bolt out.
Old Mar 12, 2012 | 05:05 PM
06Heritage's Avatar
06Heritage
Before i remove any of the torx fasteners for the first time, i heat the end of it with a big soldering iron ... this will melt the loc tite from the factory , and makes the fastener come out ALOT easier.
Old Mar 12, 2012 | 08:34 PM
Wabbit's Avatar
Wabbit
Talking
Success!!!
Thanks all for the suggestions! I used a 1/4" drill bit and took the head of the bolt off, removed the cover and the rest of the bolt unscrewed very easily.
Ok, a couple wrap up questions:
I've been told to use locktite and never seize. Locktite I know is for keeping the bolt from working loose and as I understand it, never seize is to prevent the bolt from corroding and getting stuck.
Now my question is, do I use both products?
Also, does anyone know the torque pressure for putting the bolts back in?
I found some stainless allen head bolts that should do the trick for replacement. I just have to find the right kind of washers to go with it. The washers on the existing bolts don't come off the bolts.
Old Mar 12, 2012 | 09:07 PM
smdugan's Avatar
smdugan
6th Gear
I don't know the exact specs for your bolt (5mm3.5mm or grade)
But since you used 1/4" bit to drill it out I'd guess bout 5mm shank so dry tourque for that would b less than 36 in-lb = 3ft lbs so unless you have a good in-lb 1/4 inch rachet just snug it up and if you apply loc-tite you should be good to go.
Old Mar 12, 2012 | 09:25 PM
chiefe's Avatar
chiefe
Torque specs are 84-108 in lbs. Only use one or the other (loctite/ anti sieze) On Harleys use red locktite on fastners you have no interest in removing and blue on fasteners you need to remove for servicing. In the case of the derby a small dab of blue will do you.
Cheers!
Old Mar 12, 2012 | 09:35 PM
Taddeoeg's Avatar
Taddeoeg
Why is anyone using loctite on derby cover screws? I've never seen that in the service manual and have never done it. No leaks and no problems removing the torx.
Old Mar 12, 2012 | 09:36 PM
Jmars101's Avatar
Jmars101
chiefe is correct 84-108 in lbs. and blue loc-tite, just had this exact problem, had to go with oversized drill bit and head popped right off. I got some chrome screws they have worked great.
Old Mar 13, 2012 | 08:22 AM
Wabbit's Avatar
Wabbit
Good info, thanks all!
