Flush Mount Gauge Issues
Old Mar 13, 2012 | 07:22 PM
NC D'LUXE's Avatar
NC D'LUXE
Originally Posted by fmnspooch
why don't you send em up to NJ and I'll give em a once over for ya. LOL
You got it buddy, I'll overnight them and see if you can figure these damn things out!
Old Mar 13, 2012 | 08:46 PM
82fat's Avatar
82fat
I am having trouble keeping the trim ring down on the fuel side, anyone else? I am always able to see the two way tape under a part of the ring. Ive had the dealer fix it once but it did the exact same thing.
Any suggestions?
Old Mar 13, 2012 | 09:19 PM
Blk and Chrome's Avatar
Blk and Chrome
I don't think you have an issue with the flush mounts as the speedo shows low fuel too. That would mean the sender is giving the wrong info. The tank unit and the speedo are sent the info from the sender to the ts module and then to the guages. If you fill it and niether one moves thats where I'd be looking...............By the way my flush mounts work great and have for 2 1/2 years or so
Old Mar 13, 2012 | 09:25 PM
NC D'LUXE's Avatar
NC D'LUXE
Any suggestions?
I've only run about 3 tanks of gas through mine so I haven't experienced that yet. Mine seems to be seated close with no visible adhesive.
Old Mar 13, 2012 | 09:34 PM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
Mine worked great for about two years.......now two LEDS in the middle stopped working. I'm going to take it apart and see if they are burned out or it has other problems. Good news is I can tell when I'm full and empty.
Old Mar 13, 2012 | 10:10 PM
NC D'LUXE's Avatar
NC D'LUXE
Great point there, man this site is great! Appreciate you posting and sharing your knowledge! Makes sense now there is probably an issue with the sending unit. Time to dive into the SM and here I thought I was going to get some sleep tonight, thanks!
Old Mar 14, 2012 | 06:02 AM
Great Gazoo's Avatar
Great Gazoo
Mine gave up the ghost last year, none of the LEDs work anymore. I hope its not the sender....
Old Mar 14, 2012 | 07:37 AM
Jaburg1's Avatar
Jaburg1
For those who have had them die, did you change out the gauge for a new one and, if you did, how did you remove the trim ring after it was in place? Just wondering if the finish was damaged underneath.
Old Mar 14, 2012 | 08:15 AM
NC D'LUXE's Avatar
NC D'LUXE
The finish won't be damaged if removed properly.
To remove adhesive badges or trim rings you heat the item with a blow dryer, I use an old paint stripping gun and take a piece of fishing line or something similar and work under the item in a sawing motion to remove the item. Then clean up the remaining adhesive with goo gone, I use a rag with gasoline.
At least that's the way I've done it with no issues. Patience and taking your time is key.
Old Mar 14, 2012 | 08:22 AM
Jaburg1's Avatar
Jaburg1
NC D'LUXE,
Thanks! That advice makes sense. I just want to be prepared in case I do decide on something different down the road
