Samson Exhaust
Old Mar 22, 2012 | 04:40 PM
FES's Avatar
FES
And don't forget to apply a liitle bit of high-temp red rtv silicone !!!
Old Mar 22, 2012 | 09:09 PM
norcal's Avatar
norcal
Where do I put the silicone? And do I lock tight everything
Old Mar 22, 2012 | 09:16 PM
ghostrider69's Avatar
ghostrider69
Apply the RTV to the inside of the female end of all of the slip joints (where two pipes slide together) so when you slide the male ends into them the RTV stays inside the pipe. It will help to seal the system to prevent leaks. I used blue loctite on the bolts when I installed the new seat post and the bolts that hold the tail pipe brackets to the frame and the bolts that hold the tail pipes to the brackets.
Old Mar 23, 2012 | 01:22 AM
norcal's Avatar
norcal
On the left side does the pipe go under or over the passenger foot peg, or do I need to remove it?
Old Mar 23, 2012 | 03:21 AM
tq745's Avatar
tq745
you shouldn't have to remove the footpeg. but if you do it should give you more room to work with
Old Mar 23, 2012 | 11:50 PM
norcal's Avatar
norcal
Got everything hooked up!!! I absolutely love it glad I went with the 39's will post pics tommorrow. The sound is amazing
Old Mar 24, 2012 | 12:02 AM
socal yankee's Avatar
socal yankee
Thatta boy!
Old Mar 24, 2012 | 01:35 AM
AirBoyzT's Avatar
AirBoyzT
Notice any loss of power?
Old Mar 24, 2012 | 04:51 AM
NC D'LUXE's Avatar
NC D'LUXE
Congrats! Looking forward to the pics.
Old Mar 24, 2012 | 09:36 AM
ghostrider69
Let us know if you notice any loss of power. Not that three of four ftlbs is going to make a **** bit of difference but you have to love those people that have a Dyno built into their asses. After you get a couple hundred miles on the system you might want to go back and retighten all of the bolts. Or at least check them.
