DECEL pops getting worse...
I believe it (the pop) is extra fuel burning off outside of the cylinder which also keeps the motor running cooler...What I do know is my bike was running pretty good prior to the dyno and now it is running as well as any I have ever ridden... and if this pop means that it isn't tuned right still then I guess that would be news to me, maybe fuel economy can be improved?? That isn't as critical to me as performance in HP and Tq. as well as healthy temps for the motor to live a long, high performing life.
Maybe someone who has more knowledge?? Since NASCAR went to fuel injection however, I don't see the exhaust flaming out the pipes when they are off the gas in the corner and when they had carbs they used to... So maybe there is more to this as asked by the OP??
It's either an exhaust leak or it needs more fuel at 0 throttle position
Could try giving Jamie a call at FuelMoto - he's got a ton of experience with the Power Commanders and may be willing to give some assistance, else try working directly with Power Commander. They will be able to help dial it in.
Roger
More fuel at 0 position could be the culprit. I don't have enough experience with the PCIII to add more fuel at 0 in those ranges.
When I had the 1k service done I had the dealer do the Stg1 and dyno with SERT..
I had a lot of decell popping and even a Kaboom every so often.
They redid the dyno that didn't help much, I rode it a little cause they said it would self tune it out, NOT,, I then called Rush and the TECH told me it sound like air leaks and he told me how to check for them..
Yeppers I had daylight at 5 of 8 slots where the clamps tighten..
After resealing the pipes and another Dyno tweak, the tuner got 90% of the popping out and no more KaBooms...
now I get the Jack brake sound on decelerations, with a gurggle at some Rpm's..
The retunes was all on there dime.
If I'd just had the canned map I am not sure how much diff it'd made, cause even after they resealed the muffs I still had some decell pop.
Last edited by oct1949; Mar 22, 2012 at 07:40 AM. Reason: rewrote better understanding
read the OP again..... Clearly he got a Stage 1 download from Harley.. My question, which was answered by the OP was whether the POWER COMMANDER was canned or custom...
cap letters in the OP.
DYNAJET PC III usb
read the whole thread before jumping in.
When U said canned down load I though U meant a HD down load to Ur EMc....
MY BAD...... really sorry for not reading better...
And I take it all back...
Now a whole new ball game...
If U bought the PC111 from Fuel MOTO, give Him a call and have him give U a new download for Ur set up..
HOPEfully it'll stop the decell pop..
29 lashes to me for not reading better.
