1st 1000 mile service......
Old Apr 26, 2012 | 08:53 PM
garretray's Avatar
garretray
Stage II
Default 1st 1000 mile service......
Just have a few questions.
I'm getting ready to take my 2012 Fatboy lo in for its first service. My local dealer quoted me $299. Does that sound reasonable? Or are the falling into the typical "Stealer" dealer catagory?
I also have installed the v&h naked air intake, v&h shortshots and v&h fuelpak. Should I remove the fuelpak before taking it in for service? (don't want the dealer to try and void my warranty).
Old Apr 26, 2012 | 08:56 PM
kozy22's Avatar
kozy22
Sounds about right.
Fuelpak doesn't void warranty
Old Apr 27, 2012 | 01:54 AM
Misbehaven's Avatar
Misbehaven
$300.00 for a service is about the average cost. After your first service at the dealer get the manual and start doing them your self. Not hard to do with a few basic tools just follow the check list and make the necessary adjustments and such. About the only special tools I have bought are a belt tension gauge and the oil filter wrench both for less then $40.00
Old Apr 27, 2012 | 05:03 PM
mswing1234's Avatar
mswing1234
My first two scheduled services; 1K and 5K were both $347.00 each. It was posted right on the service wall. What gets me mad is to be charged 3 hours labor (standard) and it was done in 1.5 hours. If you take it to the dealer, the price is the price.
Old Apr 30, 2012 | 02:36 PM
mrinternational's Avatar
mrinternational
What all is involved in the 1k service at the dealership. Mine is getting the 1k done tommorow, but for $300, I can go by a lift at harbor freight and do it myself next time.
Old Apr 30, 2012 | 02:39 PM
Dawgtraxx's Avatar
Dawgtraxx
Did mine myself this weekend..took about an hour and a half, dealer wanted 360.00...crazy, all parts needed, including an excuse to buy some new tools, 180.00... With synthetic in all 3 holes
Old Apr 30, 2012 | 02:40 PM
Dawgtraxx's Avatar
Dawgtraxx
Originally Posted by mrinternational
what all is involved in the 1k service at the dealership. Mine is getting the 1k done tommorow, but for $300, i can go by a lift at harbor freight and do it myself next time.
owners manual has a complete breakdown, i just went step for step, checked off as i did them
Old Apr 30, 2012 | 02:47 PM
rideflhr's Avatar
rideflhr
Dawgtraxx,
I am ready to do mine . The steering head bearing adjustment on my Deluxe is a bitch . I had another softail 2 bikes ago and it was not easy . I would like to know how you loosened the lower pinch bolts . You can barely get a box wrench on the bolt and it feels welded in . Any tips would be GREATLY appreciated .
Thnx, JIM
Old Apr 30, 2012 | 05:05 PM
Totally Bored's Avatar
Totally Bored
Talking
Originally Posted by rideflhr
Dawgtraxx,
Thnx, JIM
I used a very long wrench and yes it was on tight. I didn't torque the pinch bolts back up as I almost never torque stuff up . I did torque up the bearing to 65lbs and then I made the pinch bolts super tight. I didn't do mine at 1k miles as I was to lazy but wow did that thing get loose. I did it around 2500 miles. I did change all the fluids and all the other stuff at 1k. Looking back I should of checked the bearing at 1k. FWIW I had to take off the handlebars to get at that bearing because the socket wouldn't clear the handlebars. I plopped a towel on the gas tank, removed the 4 bolts and 2 clamp thingys holding the bars in place and plopped the bars on the tank. With the pinch bolts loose I torqued the that steering head nut. Did this last week and took a 5 hour ride yesterday. Feels great and I had the bike up to 100 mph with no issues.
Hope that helps ?
Old Apr 30, 2012 | 05:11 PM
Totally Bored
Off the top of my head.
Change fluid in all 3 holes
Adjust belt
Lube throttle
Adjust clutch
Steering bearing
Check for loose bolts
( hope I didn't forget anything)
Buying the $60 Service Manual is a must.
