pulled the wrong plug...
Old May 19, 2012 | 01:30 PM
chunks's Avatar
chunks
Default pulled the wrong plug...
was doing an oil change and mistakenly removed what the service manual calls a "pipe plug"
About 1 oz of dirty oil drizzled slowly out of the hole. Having been expecting 3 quarts, I figured out right away that I had had a brain fart and removed the wrong plug.
Found the proper torque spec for the plug, wiped it off, and put it back in.
Proceeded with the rest of the oil change.
My question is: Was that regular engine oil that came out, or did I remove lube from somewhere that needs to be replaced by doing more than a regular oil change?
This plug is in the pan directly below the cover where the oil pump and cams
are located on the bottom of the engine...
Old May 19, 2012 | 01:43 PM
luvtoride's Avatar
luvtoride
You and about 100 other guys have done that, That was a little engine oil held in the case. if it doesn't leak you're fortunate. If it does , try some Teflon tape and don't over tighten it. It's a tapered plug and you have to be very careful with it. buy a service manual.
Old May 19, 2012 | 02:06 PM
WARG's Avatar
WARG
Did same thing on my first oil change 7 yrs ago. Mine has never leaked.
Old May 19, 2012 | 02:18 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Beginning of learning from your errors, we've all done silly things over the years...no biggy.
Like posted above, if it leaks a lil teflon on it torque it back to specs.
Old May 19, 2012 | 05:28 PM
oct1949's Avatar
oct1949
Just hope U didn't crack U cases as some others in here have..
U've been member in here for 7 yrs and never read anything on that plug and not to remove it.?
Old May 19, 2012 | 06:28 PM
m i k e's Avatar
m i k e
sounds like muffler oil LMAO
harleyguy53
Aug 18, 2012 10:43 AM
thunderchild223
May 30, 2011 09:31 PM
Tonefiend
Oil Archive (no new posts)
Sep 26, 2010 09:04 AM
Revereamg
Nov 11, 2009 10:06 PM
MikeGV
Apr 15, 2006 10:22 PM
