nostalgic ac cover question
Old Jan 7, 2007 | 12:11 AM
johnpem's Avatar
johnpem
Default nostalgic ac cover question
Hi All,
I decided to dump the football air cleaner cover and get the nostalgic round one. I saw a topic a while ago where people were having problems with k&n filter and that cover, I scraped of the k&n thin gasket put on the recomended harley gasket and I notice that the back of the cover edges seem to touch the backing standoffs where the breather tubes plug into, just wondering if the guys with the s/e air filter have the same thing or does the cover
not touch the studs, I can get it tight to not spin but the rubbing thing kinda bugs me?
Thanks, JP
Old Jan 7, 2007 | 11:23 AM
hogtie's Avatar
hogtie
Default RE: nostalgic ac cover question
Nope, doesn't touch as long as I use the added gasket from HD. Can you add another gasket and just stack them?
Old Jan 7, 2007 | 11:45 AM
TexasFatboy's Avatar
TexasFatboy
Same here.
Old Jan 7, 2007 | 12:09 PM
Pastor John's Avatar
Pastor John
I had that same setup and found that the thick rubber gasket kept the cover from touching the mounting posts for the backing plate. But this caused the cover to stick out further than the football cover and it interfered with my leg. So I returned the Nostalgic Cover and purchased the new round SE cover, which fits much better. That new cover is in a supplemental catalog that my dealer had, and suspect that it's made specifically to deal with the clearance issue of the Nostalgic Cover.
Old Jan 7, 2007 | 12:13 PM
OldFenderGuy's Avatar
OldFenderGuy
ORIGINAL: TexasFatboy
Same here.
And same here as well.
Old Jan 7, 2007 | 08:46 PM
johnpem's Avatar
johnpem
Thanks guys, seems to be some fitting issues out there, i think i will put on another k&n gasket, like hogtie says, that may be just enough to get the clearance i need.
JP
Old Jan 7, 2007 | 08:50 PM
nikonf8's Avatar
nikonf8
I am not sure that the last few replies to your post caught what you are saying he mentioned K & N both of you mentioned se or stage one would not the K & N be different and possibly not fit the same. it works fine with the Harley stage one and i guess that's the same as SE but i think the key word in this post is K & N maybe i am wrong but if he has a k & N filter this may be the problem
turkey
Jan 12, 2011 05:42 PM
Big_Al47
Dec 18, 2009 12:35 AM
outback2970
Mar 14, 2008 05:57 PM
OneBlackFly
May 26, 2007 09:02 AM
Street Rob
Jun 11, 2006 12:41 PM
