Cable Length for 14" Apes?
Old May 29, 2012 | 08:31 AM
SSMNightTrain's Avatar
SSMNightTrain
Default Cable Length for 14" Apes?
Bike- '06 NightTrain
What- Need cable length for 14" Evil Apes
I am finally pulling the trigger on swapping out my drag bars for 14" Evil Apes.
I called magnum shielding to order my cables thinking they would know what length I should get....they don't.
Does anyone know the +over stock length needed to swap out stock drag bars on a 2006 Night Train for 14" Carlini Evil Apes.
If not, anyone have any suggestions to help me figure this one out.
Thanks,
Scott
Old May 29, 2012 | 01:59 PM
Vikingur's Avatar
Vikingur
Did you call Carlini? LA Choppers sells kits - you can also try asking them what lengths their cables are.
Old May 29, 2012 | 02:06 PM
FXBadass's Avatar
FXBadass
Check their website, you can enter ur model of bike and see what stock is, then figure out your + range. You got to factor your stock riser height though over a 1-1/2 or 2" riser, if I remember right.
Compare it to this: I will take 2" off my cables for 16" bars, and I got the stock short 1.5" or 2" riser, so for 14" apes on train with 1.5"or 2" riser, you should be close to this:
Clutch: 68-11/16"
Brake: 50"
Throttle & Idle: 37.5"
Wire extensions will be 12" by default, just cut and solder and be done with it.
Old May 29, 2012 | 09:13 PM
Bfranz666's Avatar
Bfranz666
Buy the bars, bolt em up, and measure. Perfect fit.
Old May 30, 2012 | 12:02 PM
MidnightRider112's Avatar
MidnightRider112
I bought +12's for my '08 train with Wild 1 14 chubby's. A little too long. Could have easily gotten by with +10's. I used Magnum Sheilding as well.
Old Jun 1, 2012 | 12:50 AM
bklynbob's Avatar
bklynbob
Why cut and solder? try these:
www.designsbynovello.com/results.cfm
Old Jun 1, 2012 | 07:34 PM
SSMNightTrain
Doing the math I was going go ahead and order the +10's. I think I am going be patient and just swap the bars out and then measure it all out. Thats good info though, thanks. BTW, do you still have the NT...and pics?
Old Jun 2, 2012 | 08:55 AM
MidnightRider112
Yep, still got it.
Old Jun 2, 2012 | 07:47 PM
deadrider's Avatar
deadrider
sick I am going to be getting some s....oon what size are they?
AussieTX
Jul 25, 2011 09:51 AM
jkoj
Oct 28, 2008 08:34 PM
mstng5point0
Sep 29, 2008 11:03 PM
CRTrain
Sep 22, 2008 08:01 PM
Subvamp
Mar 28, 2008 09:30 AM
