softail primary help...
Old Jun 19, 2012 | 05:56 AM
deedee4150's Avatar
deedee4150
Default softail primary help...
i have a softail 2003...duece carb .......and i took it apart...im stuck can anyone walkme through or is there an online manual i can find?or a primary blown up?
Old Jun 19, 2012 | 09:07 AM
SJ12DS's Avatar
SJ12DS
What is the issue? Did you take the entire primary apart or just the outer cover?
Old Jun 19, 2012 | 09:13 AM
Pierucki's Avatar
Pierucki
You could try here.
http://partsfinder.onlinemicrofiche....N-CASE-HOUSING
Good luck.
Old Jun 19, 2012 | 09:15 AM
deedee4150's Avatar
deedee4150
i took apart the whole primary.......and plus all the electricals.......check it out at my blog: koukiskustoms.blogspot.com its the softail duece bobber.....i took apart hte primary and trying to put it back together but unfortunantley im stuck.....
Old Jun 19, 2012 | 09:16 AM
suiii15's Avatar
suiii15
http://www.youtube.com/watch?v=XoZ4Vb9fNE0
Old Jun 19, 2012 | 01:04 PM
Rodzilla6's Avatar
Rodzilla6
Hey, you might want to try youtube. It's unreal how helpful some of the videos are in there. There are a bunch of HD specific ones. I was watching some yesterday about my primary repair. Great info BEFORE you get going...Hopefully, we finish mine tonight. Good luck.
Old Jun 19, 2012 | 01:10 PM
o/d's Avatar
o/d
need more details of what you're stuck on to offer any help.
Old Jun 19, 2012 | 01:16 PM
oct1949's Avatar
oct1949
Do u have access to a shop manual.???
That's usually the first thing one needs to do their own work..
I looked but the parts finder link above it the best i've found for U also..
Old Jun 19, 2012 | 01:29 PM
VETERAN75's Avatar
VETERAN75
If your going to be doing anymore maintenance yourself you may want to get the service manual, that way you have the torques for the clutch nut and the compensator nut. Cover bolt tqs inner and outer.
But if you be more specific with what part your stuck on many here can help.
STN
15
Jan 12, 2016 04:30 PM
STN
Jan 11, 2016 02:40 PM
cleanimages
May 30, 2009 10:33 AM
jebbyboy
Mar 13, 2006 09:33 PM
