Springer Risers
Putting in thread repair coils was also an easy and inexpensive task. I did that to my risers when I pinned them. Took all of a half-hour to do all four threads (and I took my time). Now that it is done these are really strong (as they should have been from the factory). $10 for the "heli-coils", $1 for the roll pin. Much cheaper than replacing the risers.
In the end, it's your bike. Just want you to have all available options to consider....
--jack
The bars are LA Choppers Nice Curvers, 1.25'' dia, 16'' tall. They might be 8-10'' across the bottom. With this set up, I am not close to hitting my tank at full lock, but that is with the FL springer, not an FX.
Pinning the bars involves drilling a hole in the upper riser clamp, and a hole in the handlebars too. These holes MUST line up, so getting the angle correct is critical. Once the hole is drilled, it's as simple as inserting a roll pin into both the riser clamp and the bars, preventing them from rolling forwards or backwards.
--jack
Plates are easy. Remove the center acorn nut, remove the risers, and remove the pinch bolt. Install is the same steps, in reverse order. Nothing tricky at all.
