My Cam Choice, I think.
Old Aug 31, 2012 | 05:06 PM
pweber6's Avatar
pweber6
Stage III
Default My Cam Choice, I think.
After reading many different opinions on Cams, I have thinking about closing the deal on the Andrews 54H. Thumbs up or down?
It going in a 2009 Fatboy, that has the 103 upgrade, 10-1 compression, and currently the SE-255 that came in the kit. Although I like the low torque in such a light bike, it dies fairly quickly on the top end....so I'm looking for the best swap.
Old Sep 1, 2012 | 08:38 AM
cwsharp's Avatar
cwsharp
Without headwork and a change in fuel deliivery I >think< you will lose something at the top or the bottom depending upon the cam. I don't have dyno tests to confirm this and your pipes have some effect also. In reality the only way to know this kind of stuff is to have your exact configuration and run dynos of each cam. Someone with a lot of >race building< experience can take the specs of your configutation and make a good guess. Just keep in mind that you should listen to those that have the cam you are thinking about in a very similar setup to yours.
Sounds like your bike is a good place to start looking for high performance though! Wish I had a 103.
C#
Old Sep 1, 2012 | 03:15 PM
dakotared's Avatar
dakotared
I went with 37H in my 2010 103 FXSTC. Seems to work pretty well.
Old Sep 4, 2012 | 07:52 PM
oct1949's Avatar
oct1949
Heres another thought/thread on Andrews cams..
https://www.hdforums.com/forum/touri...54h-57h-2.html
Old Sep 4, 2012 | 08:24 PM
eleft's Avatar
eleft
What's the PSI on a compression test?
Old Sep 4, 2012 | 10:53 PM
pweber6's Avatar
pweber6
Stage III
Well...I should know what the compression is with the current set up, but I don't. So after I take a measurement with my current set up (SE255 cams), how much of a change are you thinking I will get with the Andrews 54H? (The SE255 are generally not know for easy starting, and I have not had any starting problems.)
jmd897
Feb 14, 2017 05:19 PM
C45H
Engine Mechanical Topics
Dec 21, 2015 10:41 PM
elwoodto
25
Mar 27, 2015 12:32 AM
infanterene
Exhaust System Topics
32
Jun 16, 2010 09:16 PM
marty44
Feb 27, 2008 09:59 AM
