Back fire everytime I get off the throttle
Old Oct 7, 2012 | 04:12 PM
dojodragon's Avatar
dojodragon
Default Back fire everytime I get off the throttle
Hey guys, I have a 2001 deuce and every time I drive it and get off the throttle it pops alot out of the exhaust. I have a set of Vance Hines exhaust and that's the only mod. Someone told me I need a computer tune, maybe its running too lean. Any help in the right direction will help, thanks.
Old Oct 7, 2012 | 04:23 PM
Misbehaven's Avatar
Misbehaven
If it is just a little popping and gurgling sound It could be running lean. If your getting a loud back fire and loud popping you could have an exhaust leak at the cylinder heads.
Old Oct 7, 2012 | 05:17 PM
CSS_FXD's Avatar
CSS_FXD
I believe if it's out your pipes it's too rich. Out your carb it's too lean. My old carved bike would have carb farts all day long till I gave it bigger jets in the carb to fattin up the mix then it ran like new.
Old Oct 7, 2012 | 07:39 PM
Raddazzz's Avatar
Raddazzz
My bike was doing the same, i have dual exhaust and both of my muffler clamps had came loose.
Old Oct 7, 2012 | 07:59 PM
olongapo1's Avatar
olongapo1
1st, Check for exhaust and or intake manifold leaks.
2nd, If you are running open pipes you may need some sort of baffle to build the proper amount of back pressure.
3rd and last would be a computer tune. Many options here.
Old Oct 7, 2012 | 08:03 PM
Jenn1200XL's Avatar
Jenn1200XL
What pipes do you have? I had very short pipes on my Sporty and had the same issue. If they are very short, you could just be not getting enough back pressure. I'm a sucker for the short pipes, don't like anything covering the back wheel.
Old Oct 7, 2012 | 08:35 PM
dojodragon's Avatar
dojodragon
First off, thank everyone for the responses. My bike is fuel injected and it would seem that most of you guys think its a air leak in the exhaust. So I'm going to check on that as soon as next weekend and I will post the results. Also I'm not sure what series V and H pipes they are, but they are full lenth. Thanks again.
Old Oct 10, 2012 | 07:19 PM
airborneretired's Avatar
airborneretired
Default Popping
I have a 08 softail deluxe with v&H big shot staggered and a/c mod and had HD do the computer remap because of mods, mine too backfires when I let off the throttle? I think its running lean? If you find out please post I am thinking of buying the V&H fuelpak to richen the system up.
David
Old Oct 10, 2012 | 09:34 PM
QC's Avatar
QC
Dojodragon, a picture would help us identify them. If they are Longshots, make sure baffles are in them. Until I put baffles in mine, It popped like crazy. Either the stock baffles, or the DKCustoms Thunder Torque inserts will help.
Same goes for you, airborne. Also, if you go with a tuner, consider if you are going to do any further mods to the engine before you decide on a tuner. From what I've seen in here, the Fuelpak can be troublesome. Better tuners are available for the same $$$.
Cuchulain
EVO
11
Jun 27, 2017 04:11 PM
FICS1
Carburetor Related
May 9, 2015 04:57 AM
Bob Cosby
Apr 22, 2010 04:30 PM
jmann8686
Apr 26, 2009 09:49 PM
zenwarrior
Exhaust System Topics
Jun 8, 2006 07:51 PM
