Wierd noise when starting?
Old Nov 2, 2012 | 03:15 AM
J-Dog's Avatar
J-Dog
Default Wierd noise when starting?
Hey Fellas,
Every once and a while, when starting my bike it will make a weird clunking noise, then i try to start it again and it works fine. Any Ideas...?
Thanks fellas,
Jason
Old Nov 2, 2012 | 05:53 AM
Guitardude's Avatar
Guitardude
Originally Posted by J-Dog
Hey Fellas,
Thanks fellas,
Jason
I make wierd noises when I first start, too...it just happens. I'm old and have a lot of miles on me, and honestly, if I woulda known I was gonna live this long I woulda taken better care of myself.
As for the bike, could be any number of things...like maybe where the engine is in the compression stroke?
Old Nov 2, 2012 | 06:22 AM
oct1949's Avatar
oct1949
check out Ur compensator, may need to be tightened.
Old Nov 2, 2012 | 06:38 AM
phanowel's Avatar
phanowel
Maybe starter beginning to go? Or weak battery? Not enough juice getting through to get the pinion gear out and spinning.
Old Nov 2, 2012 | 07:54 AM
JohnnyC's Avatar
JohnnyC
Have your battery tested under load. A weak battery is often the cause of this being intermittent.
Next would be a bad compensator. By 2011 most OEM compensator were the newer S&S, which is now standard on all models (for a reason).
Could also be in the starter itself.
Old Nov 2, 2012 | 10:35 AM
Hogpro's Avatar
Hogpro
Former Sponsor
If it has a built motor and heads that could have something to do with it as well assuming there are no compression releases. You didn't really give much information.
Old Nov 2, 2012 | 10:54 AM
spydyr's Avatar
spydyr
+1. Compensator is recoiling after the compression stroke. It might need new springs.
Old Nov 2, 2012 | 10:59 AM
golfblues's Avatar
golfblues
My 09 Heritage did the same thing. I just put in a new SE Compensator. Clunk is gone. I had a nice piece of aluminum missing from my inner primary by one bolt hole from the chain slapping it. Problem solved.
C908
Apr 5, 2022 01:10 PM
crazycanuck
Engine Mechanical Topics
Feb 20, 2014 10:46 PM
customsoftail200
Jan 11, 2013 07:17 PM
hays59
Aug 25, 2012 11:23 PM
nealhix
Apr 19, 2012 02:40 PM
