Quick cable length question for beach bars
Old Mar 21, 2013 | 11:28 PM
Pepsimayn's Avatar
Pepsimayn
Default Quick cable length question for beach bars
Hey guys,
Wanted to check before I order and have even more issues. I am going to be using Carlini High Roller risers and LA Choppers beach bars. The stats on the bars are:
Width: 36 inches
Center Width: 8.5 inches
Rise: 2.875 inches
Pullback: 14.75 inches
They were almost exactly the same when I laid them next to my burly bikinis.
Do I need +4" or will +2 work on the throttle/idle/brake?
I'm doing a tank shifter so I don't need the clutch!
Thanks a lot!
Old Mar 22, 2013 | 09:52 AM
Pepsimayn's Avatar
Pepsimayn
Damn, no one?
Old Mar 22, 2013 | 11:55 AM
Knucky's Avatar
Knucky
I doubt you will need anything but maybe I'm misunderstanding the situation.
Old Mar 22, 2013 | 06:55 PM
Pepsimayn's Avatar
Pepsimayn
Going from stock bars/risers to beach bars and 1.5" risers.
when mocking them up they barely reach and get tight so I don't know if I need +2 or +4...
Old Mar 22, 2013 | 10:26 PM
fatboy100's Avatar
fatboy100
I installed Big Johnson bars on my 03 fatboy and did not need to replace cables. JP Cycles has a fitment chart. below is the specs.
Manufacturer Part Number:BA-7390-01B
Diameter:1-1/4″Center Width:3-1/2″Height:5″Material:SteelFinish:BlackRise:5″Wi dth: 38″Pullback:13″
Hope this helps.
Old Mar 22, 2013 | 10:33 PM
fall guy's Avatar
fall guy
I put Burly Bikini beach bars on my Heritage and did not need to extend the cables, but extended the wiring 4 inches and used a 48" brake line. Good luck!
Old Mar 22, 2013 | 10:51 PM
2010Deluxeguy's Avatar
2010Deluxeguy
+2 will work....4" is too long...ask me how I know
Old Mar 23, 2013 | 11:00 AM
Pepsimayn's Avatar
Pepsimayn
I'll bite, how do you know? It would seem like a little long wouldn't be too bad. Why didn't that work?
It seems like the brake like will be the limiting factor, more than the throttle cables
Old Mar 23, 2013 | 10:00 PM
Pepsimayn's Avatar
Pepsimayn
48" on the brake line is +4". Is there a good amount of play in it? Need to order soon... I'm going to go with +2 on the throttle/idle for sure. Do you think +2 or +4 is better on the brake?
Thanks a lot guys. Promise more pictures when I get it all together
Old Mar 23, 2013 | 10:59 PM
jimmers1817's Avatar
jimmers1817
Don't know if the stock lengths on an 08 are the same as a 12 but when I put 518s on the wife's 08 Deluxe I went with 48" (+4) on the brake line and it's a good fit. May have been able to get by with +3.
Stock Deluxe risers
35.5 " wide
12" center
5.5" rise
14.25" pullback
way I figure that's about 2" more pullback and more than twice the rise as your setup. So providing the 08 stock lengths are the same as the 12s you may in fact be okay with +2. Hard to say. Way I determined my length was to install the new bars and hold the controls up to where they would be and added whatever was needed. While of course maintaining the correct routing and lock to lock range of motion or the bars. Unless someone has an identical setup, anything else is pure guesswork, no?
Hoginedgewood
Jan 28, 2019 03:39 PM
K9BO
May 28, 2012 11:37 AM
matwal84
Softail Parts
Jan 31, 2012 05:10 PM
Markske
Feb 15, 2011 10:25 PM
rns99
Jun 23, 2008 07:25 AM
