It took me a while to mess with it but I picked a side and locked it down then fanagled the other to get it lined up. It was a major pain in the *** though, I found it best to lock down the left side first then working back to front set the right side.
I did left side first because I wanted as much of the second pipe into the head pipe as I could get and not have it move, plus its a pain to get to that allen bolt. Right side is easier to mess with since it's just loosening the flange nuts and bracket.
mine was a PITA to install also. couldnt get them to line up...so i laid the brackets on the floor flat and behold... i actually had one warped bracket...which i sent back (samson confirmed it was in fact warped) and sent me a new one.
i also used a couple of flat washers inbetween the brackets and the frame (on the front bolts only) to even out the closeness to the tire.
