Stage1 and Damage.
Old May 31, 2013 | 11:15 AM
Softail HA's Avatar
Softail HA
Default Stage1 and Damage.
Just finished putting on my screaming eagle heavy breather, I already have my Vance and Hines pipes on. The dealer can;t get me in till Monday ,for the stage one download. Should I worry about driving it over the weekend, or will I be okay as long as I am easy on it. 2011 Heritage.
Old May 31, 2013 | 11:21 AM
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
This reminds me of a thread I posted when I was doing my Stage 1.
You'll be fine over the weekend.
However, you may want to reconsider that dealer download. There's been mixed success with them. It's a canned download and doesn't always work out well with every bike. (Won't hurt your bike, just doesn't always give the desired results.)
Search XiEDs and ViEDs on this site for an alternative if interested. Basically, it's a 100 buck device that you plug into your 02 sensors to adjust the fuel richness. Install takes about 10 minutes. Love mine. My Slim is running great with them.
Old May 31, 2013 | 11:36 AM
jam436's Avatar
jam436
What he said...
My stage 1 remap was nothing more than a canned download installed by the dealer, and as such it still complied with EPA emissions requirements - meaning it will still be too lean.
All it did was it tweaked the timing, and increased the rev limiter to I believe 6200, but it didn't touch the AFR.
As a result, it ran well, but it also ran hotter with more decel popping.
ViED's solved both those problems.
Oil temps dropped by at least 20° and the decel popping all but vanished - and the bike never ran better.
Old May 31, 2013 | 11:58 AM
Chunker's Avatar
Chunker
Or call Fuel Moto and get one of their fuel injection programmers. I got the PC V and they loaded it with a dyno program based on my equipment. I'll install it when the quiet baffles come in. For a 13 Fatboy
Old May 31, 2013 | 12:23 PM
Bluraven's Avatar
Bluraven
+1 on Calling Fuel Moto and getting a fuel tuner like a DynoJet "Micro Tuner".
Better yet, go an e-bay and find a used Vance and Hines Fuel Pak for under $150.
My 09 Heritage had the dealer stage 1 download on it and the bike ran well but had decel pop and the fuel mileage sucked at around 36 mpg.
After I added the Fuel Pak, the oil temp dropped around 20 degrees, the decel pop was gone and on the last three road trips I got around 43 mpg.
Old May 31, 2013 | 12:24 PM
Softail HA's Avatar
Softail HA
If i lived in the US i would order a tuner in a second ,problem is anything I order now is probably three weeks out before I get delevery.
Old May 31, 2013 | 12:34 PM
Jake911's Avatar
Jake911
Isn't there an issue with a non-HD tune and the factory warranty?
Ramboamt's Avatar
Ramboamt
You can run it for awhile until you get your Fuel Moto tuner. You just have to remember NOT to get on the throttle heavily and watch/feel for high engine temps.
Or just put back on the stock air cleaner until you have the tuner, that way the air cleaner will restrict the air flow and "fatten up" the fuel mixture.
I would go with the "Fuel Moto" Micro tuner, unless you are going to do more mods than just the stage 1. Call or Email Jamie at Fuel Moto and he can tell you what you would need for your bike to run perfectly.
My
Old May 31, 2013 | 03:30 PM
steamybob's Avatar
steamybob
Forget the H-D canned tune. The way I had it described was like tuning in to a radio station - with the canned tune you'll be able to hear the music playing, but you won't get it in absolutely perfect spot-on stereo.
My Indy did mine with the Direct Link Flash-Tuner - stunning results - runs like a sewing machine and goes like **** off a shovel!
At the time my bike was less than a year old, but I wasn't over bothered about the warranty - my Indy is ex-H-D trained and has forgotten more than the stealership will ever learn!
Old May 31, 2013 | 03:35 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Personally, I'd wait. I'm not in that big of a hurry, since it's a couple of days. If it was a week, that's different.
