Help with NOISE
Old Jun 10, 2013 | 09:28 AM
cravej1's Avatar
cravej1
Default Help with NOISE
Would a bad compensator spring cause the following noise.
When at operating temp and under load
Rattle in front of primary
Sounds like it travels to rear cyl top end
Just prior to shifting sounds real loud on leftside
99 EVO
LOTS of work
Old Jun 10, 2013 | 09:53 AM
fadi77's Avatar
fadi77
Default your bike issue
hi I think its common issue with these bikes ...
read this link you may find it helpful:
http://www.****************/forums/t...or-sounds.html
good luck
Old Jun 10, 2013 | 09:56 AM
cravej1's Avatar
cravej1
Default Link
Could not open the link
Old Jun 10, 2013 | 10:04 AM
fadi77's Avatar
fadi77
http://www.****************/forums/t...pring-cup.html
check now
Old Jun 10, 2013 | 10:05 AM
fadi77's Avatar
fadi77
Old Jun 10, 2013 | 10:10 AM
fadi77's Avatar
fadi77
for some reason the link is not working here
Old Jun 10, 2013 | 10:17 AM
fadi77's Avatar
fadi77
listen
Open Google and write (compensator spring harley) you will find an article on v-twinforum . com (Primary/compensator Sounds) just click it and read.
if you still have an issue let me know
regards,
FADI
Old Jun 10, 2013 | 11:46 AM
JohnnyC's Avatar
JohnnyC
The link has a blocked segment probably due to the fact it's a link to a competing forum.
Have you opened up the primary to see inside yet? It could be so many things from a bad compensator to a lose primary chain. The clutch hub could have loose bolts, the compensator bolt (nut) could be backing off and unscrewing. You could have a bad clutch hub bearing or the more common Inner Primary Bearing (IPB) is worn. It may even be bearings in the transmission.
Do this, search for IPB in this forum (search button on the above tool bar) and do a bit of studying up and trouble shooting yourself. By reading other's posts that are similar to your issue, you can really educate yourself.
Do you have the service manual. EVERYONE owning a Harley should buy the FACTORY service manual, it specifically identifies your issue and how best to fix it. Trying to fix someone's bike over the internet is nearly impossible.
Old Jun 11, 2013 | 12:15 PM
cravej1's Avatar
cravej1
Default I think I found the problem
Opened up the primary last night and pulled off the compensator.
Since it's the 1st time I’ve pulled one off, my question is should the spring inside the compensator be loose and rattling around with a light jiggle of the compensator. I am thinking not. I can move the spring around with my finger and the spring has more then a 1/4" of in and out movement.
Old Jun 11, 2013 | 12:23 PM
golfblues's Avatar
golfblues
Are you sure you pulled the compensator off? There are 2 ways to take it off, one is to remove the inner primary which is involved & the other is to grind off the inner primary lip from about 5 to 11 o'clock so the compensator slides out. I assume it's the softail in your sig.
Your description sounds like a ping under load. I had to retard the timing on my 09 Heritage Tmax as the map I was using was to advanced. All gone now.
