totally confused
Old Jun 30, 2013 | 09:35 AM
sandtrap10's Avatar
sandtrap10
Cool totally confused
had to drop 2002 heritage off at dealer yesterday the speedo, odometer, turn signals and check engine light all quit while riding around in the country. when I would come to a stop the bike also wanted to stall had to keep it running giving it gas till light changed. when I dropped it off he tried to do a diagonistic by pushing trip button and turning on switch at the same time, even that didn't work. any ideas.
Old Jun 30, 2013 | 09:49 AM
Tracker56's Avatar
Tracker56
Check the crank position sensor down by the oil filter. Make sure the connector is tight. When that goes bad the ECM doesn't know what is going on and will do all kinds of strange things.
Old Jun 30, 2013 | 10:03 AM
fcsallan's Avatar
fcsallan
Bad connection at the computer. Or a bad ground.
Old Jun 30, 2013 | 06:12 PM
scooby636's Avatar
scooby636
I had the exact same problem and it turned out to be bare wires under the front fender going to my front fender light. It would happen randomly mainly during turns from stop to start.
Old Jun 30, 2013 | 06:31 PM
Blk and Chrome's Avatar
Blk and Chrome
speed sensor? I replaced mine for the same issues
Old Jun 30, 2013 | 06:47 PM
checkers's Avatar
checkers
Check battery cables, make sure they are clean and tight, This can also be caused by shorted fender tip lites, usually on the rear or speed sensor. Also if you have a tuner installed in line with the ECM, unplug it. Perform a wiggle test on the ECM connections. After that, it's a step at a time.
Old Jul 1, 2013 | 01:30 PM
sandtrap10's Avatar
sandtrap10
Smile
Thanks for the help everyone. Will post fix when I find out what the problem is, again thank you everyone.
Old Jul 1, 2013 | 02:51 PM
olongapo1's Avatar
olongapo1
I'm also inclined to believe your stalling issues could be related to the Speed Sensor. Keep us updated.
danzio
Oct 9, 2016 09:04 AM
schwingding
Sep 15, 2011 06:26 AM
WNMORE
Jun 14, 2011 05:11 PM
INTHERED
Jul 14, 2009 06:31 PM
nthanker
Oct 30, 2006 01:29 PM
