Installing these rear axle nut covers on my 2012 FB http://www.harley-davidson.com/store...-nut-cover-kit
The left side isn't a problem, but the right side will not fit as it hits the muffler.
The instructions do say to adjust the muffler so the cover doesn't hit the muffler. But I see no way to adjust the muffler as much as needed to clear this cover.
Anybody have any ideas ? Anybody ever install these on a FB ?
I'm rather surprised they actually stick out that far.
However, you need a new exhaust anyway. The stocks have to go. Not to mention, the exhaust currently hides your axle covers anyway, so what would the point be?
For now, maybe just use the left one. Nobody would know the difference until you change exhaust.
Phhht, those are the cheaper ones... Are you serious? I paid 42.95 for plain black ones up front! Don't ever look at the HD parts catalog or you might pop a vien! hah!
If you have a lift, raise your bike a bit. Doesn't really have to be off the floor. Should give you enough room.
I have the bike on my lift, the rear wheel is off the floor. There is no way this sucker is going on.
I did install just the left one. But from behind the bike it really looks unbalanced that way.
i have the fatboy lo with the rush slip on mufflers . i have the black nut covers they fit fine but the muffler side the black cover rubs the rush slip on mufflers i took it off
