front end wobbles
Old Oct 12, 2013 | 08:02 PM
  #31
eleft's Avatar
eleft
Originally Posted by coastb
I ride a 07 Deuce with drag bars and when I throttle off the front end wobbles. It only happens at speeds above 50mph. If I lean on the bars or pull on the bars it stops. Just wondering if thats normal. The front tire does need replacing soon. Maybe not balanced properly or the drag bars have an effect.
Rear tire (cupping) lumps could be the culprit also.
If the front is shot why try to save the rear to get more mileage?
Then you find you have the same problem by not changing the rear at the same time.
Ask me how I know?
answer: been there done that
Al
Old Oct 15, 2013 | 08:09 AM
  #32
Whisper123's Avatar
Whisper123
Stage I
My 97 Softail had a wobble at 35 when I would go 40 it was gone and at 30 it was gone.
I had a New tire and New wheel bearings. I lostened the upper tree pinch bold and tightend the top nut 1/4 turn and the problem was gone. If You try this make sure that You have no binding when You move the forks
oldcorps116
EVO
17
Sep 2, 2013 05:59 AM
LCCXL1200X
Jun 19, 2013 12:23 PM
Johns98roadglide
Jun 11, 2013 10:20 AM
Johns98roadglide
Jun 10, 2013 06:33 PM
NTrain177
Jul 3, 2012 09:13 AM
