oil capacity ?
Old Mar 10, 2007 | 03:19 PM
06DEUCE's Avatar
06DEUCE
Default oil capacity ?
how much does the bike take on a filter and oil change? the book says no more than 3.5 qt. i only got 2 qt in and it was full?
thanks
Old Mar 10, 2007 | 05:21 PM
1deuce3's Avatar
1deuce3
Default RE: oil capacity ?
Mine takes3 qts. I drain and refill it while it is level on the jack.
Old Mar 10, 2007 | 06:08 PM
hdpearson13's Avatar
hdpearson13
does anyone get 3.5 in i get 2.75 to 3 in i use a jack and drain and empty it on the jack
Old Mar 10, 2007 | 06:10 PM
06DEUCE's Avatar
06DEUCE
i did the same. still only got 2 in. i did do it cold? maybe more would have drained out if i warmed it up????????????
Old Mar 10, 2007 | 06:17 PM
anubisss's Avatar
anubisss
Some of the oil remains in the engine with type of system. I think it is called sumping or something.
Old Mar 10, 2007 | 06:22 PM
WARG's Avatar
WARG
You should get only about 2.8 - 3 qts.in. I put 3 full quarts in mine on my first service and was blowing oil out the vent hose b/c it was too full. I keep mine at about 75% on the Full HOT range marker.Some oil does remain in the engine as mentioned above.
Old Mar 10, 2007 | 09:51 PM
jerseyjeff62's Avatar
jerseyjeff62
YOU SHOULD WARM THE OIL UP FIRST THEN DRAIN IT,I BELIEVE THE MANUAL SAID THAT
Old Mar 10, 2007 | 11:35 PM
HD7585's Avatar
HD7585
If you drain it cold, a lot of old oil will still be in the engine. Always drain the oil HOT
Old Mar 11, 2007 | 12:05 AM
hdpearson13
what if the bike hasnt been started in six months due to your to busy helping out the iraqi population
Old Mar 11, 2007 | 03:18 AM
hambone's Avatar
hambone
ORIGINAL: 06DEUCE
thanks
It's called scavenging. Check this web site for information about it. http://www.roguechopper.com/ Recommended by my mech when I went from dino to full syn oil.
Rick
