Front sprocket change
Old Nov 19, 2013 | 10:21 AM
star2nv's Avatar
star2nv
Default Front sprocket change
Anyone change the front sprocket / pully on a 5 speed transmission. Give me some input on how you like it
Old Nov 19, 2013 | 05:06 PM
oct1949's Avatar
oct1949
Sorry I don't remember anyone with a 5sp.
I do remember a member that changed the front on a 6speed couple yrs ago..
U have to be really careful and Do Ur math real good..
Seems I remember he dropped two teeth for faster acceleration
Afterwards he complained his bike was running WAY to many RPM's at 70mph,
Old Nov 19, 2013 | 08:39 PM
Greabert's Avatar
Greabert
Just put an Andrews 34 tooth on my '02 Heritage a month ago. Like it a lot better than the stock 32 tooth, I feel it should've come this way from the factory. I installed it myself so it took me twice as long to install as what the shop quoted for shop time. Ended up chop sawing a standard 1-7/8ths socket in half and welding in a piece of pipe to make it a deep enuf socket to get the pulley nut off. Also just used a piece of brass stock put between chain and compensator as a chain lock. Pretty straight forward if you do the job yourself and lots of how to info online. Well worth the time and $$$ IMO.
Old Nov 20, 2013 | 12:30 AM
star2nv's Avatar
star2nv
Going to the 34 tooth did first fear seam sluggish and did 5th feel almost like a overdrive
Old Nov 20, 2013 | 07:44 AM
Greabert's Avatar
Greabert
First felt much better. I always felt the stock gear ratio's were too steep. 5th is also way better. 75mph now feels like 65mph used to. Haven't checked my mpg yet but I suspect it's going to be better too. Shy of looking it up, I think Andrews claims the final ratio goes from 3.150 to 2.916 with the 34 tooth which is just about the same final ratio as the newer 6 speeds. Only problem I see with it is that I didn't do it sooner!
Old Nov 20, 2013 | 10:24 AM
asputin's Avatar
asputin
I changed the front compensator sprocket on my 5 speed.much easier.25 to 27 tooth I think...dont have to take off inner primary that way.
Old Nov 20, 2013 | 10:39 AM
asputin's Avatar
asputin
from Illusion motorsport
Old Nov 20, 2013 | 01:30 PM
Greabert's Avatar
Greabert
Were you able to use the stock primary chain with it?
Old Nov 20, 2013 | 08:59 PM
asputin's Avatar
asputin
no,it came with longer chain
Old Nov 20, 2013 | 10:58 PM
Greabert's Avatar
Greabert
I saw the 27 tooth sprocket kit on their site. About the same $$$ as the front pulley, but you are right it would be less work. More than one way to skin a 5 speed cat.
