Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jul 17, 2014 | 07:40 AM
  #1011
NAME CHANGE REQUIRED's Avatar
Originally Posted by JimGnitecki
Sorry.
Jim G
Accepted thanks
Old Jul 17, 2014 | 08:42 AM
  #1012
Hunter5179's Avatar
Hunter5179
Originally Posted by harty
Hey Hunter,
I noticed in your pics it looks like you have flipped your risers 180 degrees and your bars are sitting higher. How tall are you and how do you find the change. I ask as I am quite tall(6'4") and have been looking at different ideas to bring the bars up a litttle higher. Are you leaning forward much more than the standard setup now?
Cheers
Harty
Hey harty, I'm 6'2. The bars are actually really nice for me in that position. They sit a little more forward and up which makes me sit better. I think you should try it out since you are 6'4. It's real easy to flip the risers around. I had to do that because my blackline tank cover was rubbing the speedo so I had to improvise. At 6'4 you might be very happy doing this. Let me know how it goes if you try it.
Old Jul 17, 2014 | 10:56 AM
  #1013
Stone Cliff's Avatar
Stone Cliff
Just put a 250 Dunlop on the rear... I can definitely see the difference. Thanks 24v for the idea.
Old Jul 17, 2014 | 02:57 PM
  #1014
Yo Nadz's Avatar
Yo Nadz
Hunter, I noticed you trees are powdercoated. I've got my bars and risers off right now because I'm in the middle of installing apes. I was debating on removing both trees and having them coated but got kinda intimidated by the photos in the service manual. Looks like there are a lot of moving components in there. Was removal and installation pretty straight forward as long as you put everything back how it came out, or is there more to it? Any insight is appreciated. I'm pretty good with a wrench, but don't want to mess anything up in the front end. Thanks for the help!!
Old Jul 17, 2014 | 03:19 PM
  #1015
Yo Nadz's Avatar
Yo Nadz
A little clarification to the above post. I looked at the manual again. I guess my question boils down to IF i removed the upper and lower bracket from the steering head WILL the bearings and bearing races STAY INSIDE the steering head, or will they FALL OUT of the steering head once the upper and lower mount with the fork stem are removed??
The manual states if the bearing races are removed then the bearings need to be replaced...so I'm assuming those will stay inside the head unless I force them out??
Old Jul 18, 2014 | 12:59 AM
  #1016
Hunter5179's Avatar
Hunter5179
Bearings will not be affected. They stay on the stem.
Old Jul 18, 2014 | 09:52 AM
  #1017
Goldsgym's Avatar
Goldsgym
Originally Posted by Hunter5179
Does anyone's breakout when going straight look like the handle bars are crooked?
Mine does
I think it's from the dealership when the finish the assembly.
There are rubber bushings in the risers and they don't torque them down evenly.
I re-tightened my and it improved
Old Jul 18, 2014 | 09:58 AM
  #1018
Goldsgym's Avatar
Goldsgym
Mine does
Old Jul 18, 2014 | 05:49 PM
  #1019
Hunter5179's Avatar
Hunter5179
Swapped the tank emblem out. I think this is more fitting.
Old Jul 18, 2014 | 06:26 PM
  #1020
Pa-Rider's Avatar
Pa-Rider
Those cvo skull tank badges look so much better..
