Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Dec 21, 2014 | 07:23 PM
  #1771
asputin's Avatar
asputin
Ok thanks guys,guess ill buy myself expensive lights for Christmas..
Old Dec 23, 2014 | 01:53 PM
  #1772
xSUITTOx's Avatar
xSUITTOx
Default 260/40/18's, will fit the stock rear wheel/rim ?
Originally Posted by 24v
Every 18" tire up to, and including, a 260/40/18 will fit the Breakout. Amount of lowering does not matter. It would fit with the shocks completely removed even.
Old Dec 23, 2014 | 03:24 PM
  #1773
24v's Avatar
24v
Yes it will.
Old Dec 23, 2014 | 04:13 PM
  #1774
xSUITTOx's Avatar
xSUITTOx
Yes it will.
What's the actual width demensions of the stock rear breakout wheel ?
Old Dec 23, 2014 | 05:00 PM
  #1775
Alain's Avatar
Alain
Pretty sure it's 18x8.5
Old Dec 23, 2014 | 05:21 PM
  #1776
24v's Avatar
24v
[edit]I was wrong, they are 18x8.[/edit]
Old Dec 24, 2014 | 07:18 AM
  #1777
xSUITTOx's Avatar
xSUITTOx
Default Confused about stock wheels
Yes it is.
http://www.ebay.com/itm/08-15-HARLEY...b94107&vxp=mtr
If you look at the specs of the Turbine wheels for Breakout, it says for FXSB
18x8
Tires: 240/250/260/280
What's the maxium width rubber on a 8.5 rim that will fit ?
But according to Heartland, you can put the 280, but a change of belt to 20mm.
Old Dec 24, 2014 | 07:27 AM
  #1778
24v's Avatar
24v
The wheel actually is 8", my bad. I was going from memory, but I just went out to the garage and looked.
You might be able to get a 280 under the stock fender with some creative spacers and a narrower belt, but it would be a hell of a squeeze.
As for a 280 on an 8.5" wheel, I think that is fine. I wouldn't go any bigger than a 250/260 on the stock wheel personally.
Old Dec 24, 2014 | 04:03 PM
  #1779
Alain's Avatar
Alain
My bad for the bad info. The rocker rear wheel is 18x8.5 so I assumed the breakout was the same thing.
Old Dec 25, 2014 | 11:28 AM
  #1780
Stone Cliff's Avatar
Stone Cliff
Default Breakout Console/tank bib - Something different
Used some extra Stingray from the seat
