• Customizing you bike
• Seats
• Risers
• And much more!
Wow, that's cool! Be SURE to post some photos once the bike is all back together!
Well finally the Supercharger is being installed. We got bit delayed waiting for bigger injectors and also the Supercharger had to be slightly modifed for the 110 engine as it was originally designed for the 96 / 103 engine.
The tuning will then be completed on Tuesday on a Dyno and am hoping to have the bike on Wednesday.
As this supercharger is beltdriven centrifugal type then the boost gradually increases with Rpm. In order to get hight boost and torque at lower Rpm then the gearing of the supercharger has been slightly altered and the engine RPm will be limited to 5600 in order not to overspeed the supercharger.
I prefer low to midrange power rather than getting few more Hp at very high Rpm..
Here are pics of the installation.. will then post the dyno results on Tuesday
Pretty sweet- I'm sure you can;t wait to take her for a spin. So what size injectors did you end up with, and did you retain the stock TB or go with a larger one as well? I'm guessing the 110 TB should be ok.
One thing you may want to consider is swapping the front belt pulley for a 30T - I think the one from a Tri-Glide fits directly. You may or may not need to swap to a shorter belt. Normally you would also increase the rear pulley to 68T but I've been told the CVO uses a pulley that is specifically machined for the CVO wheel, so you're kinda stuck with the stock 66T.
The 30T front will give you an improved final drive ratio, much faster off the line and roll-ons, making better use of the S/C's grunt. HD has been setting the final drive ratios very tall on newer bikes for meeting EPA standards. If you go back to the FXR days, bikes always came with a 3.23-3.73 final drive ratio (something like that) and felt more peppy, whereas our newer bikes have ratios in the mid-2's making them feel a lot more pokey. Anyway just something to consider for later.
Good luck with the build wrap up and interested to see what the dyno sez
Jim G
Just really needs about 10% more gearing, as you alluded to above, but with HD's latest parts changes, it's super expensive to get even 6.5% more rpm.
Jim G
Hi LA_Dog
I am not sure what Injectors Richard at TTS put in. I can find out and post later. I have the standard 103 Throttle Body and will keep that for time being.
If I go for further power mods then guess would go for the 131ci Jims engine with much bigger Throttle Body and look at some Intercoller options.. this kit cools the Intake air about 30 degrees by use of expansion chamber but further cooling would improve performance drastically.
I will see how the bike reacts with current gearing and am hoping all the extra low to mid range power will go well with the current gearing.
I am really hoping the bike will be fantastic cruiser with this setup and am kind of hesitant to go for much more.. as just the Jims 131 engine will cost me similar as installing Stage 3 Supercharger kit in my Triumph Rocket 3 which would give me just short of 400 RWHP for the Rocket...
And in case you are wondering.. yes I do love power
My car is Mercedes CL600 V12 Twin Turbo with various mods and been tested on Dyno with 593HP and 1053FTLB of Torque.. True Monster
Will post both Dyno results and pics when I get the Breakout back
Price: $356
Discount code for this weekend only: MEMORIALDAY5 -$17.80
Shipping & Handling (Free Shipping US Only - Free) $0.00
Grand Total $338.20
http://www.easternperformance.com/pr...y-softail.html
nothing wrong with a lot of ponies either two wheels or four
Jim G
