Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jun 4, 2015 | 10:59 AM
  #3081
LA_Dog's Avatar
LA_Dog
Sculpture Cycles is a US dealer for BSL and carries the pipes for VROD. Check the prices. nuts.
http://www.sculpturecycles.com/c-Exh...pipes-Vrod.htm
[EDIT] - Found their entire price list for all pipes on all HD bikes. http://www.sculpturecycles.com/a-PriceList-BSL.htm
Old Jun 4, 2015 | 11:08 AM
  #3082
jgos929's Avatar
jgos929
I understand you have to recoup your cost for a half million $ cnc milling machine and what not and I realize what all goes into it but..... Oh never mind forget I even said anything.
Old Jun 4, 2015 | 11:09 AM
  #3083
NSR's Avatar
NSR
All right gang, I'd like to hear the opinion of the crowd on something. I need to extend my forward controls. I really don't want to use the Ness extension plates.
Harley makes this simple kit -
http://www.harley-davidson.com/store...-07-4922308--1
Like nearly everything else, H-D says it won't fit a Breakout. But they say it WILL fit a 2008-2011 Rocker/Rocker C.
So, I dug around a little on this "parts finder" tool I ran across:
http://partsfinder.onlinemicrofiche....artsfinder.htm
Well, it turns out that the 2014 Breakout and the 2011 Rocker use the same brackets on both sides! Cool.
Should I roll the dice & give these brackets a try?
I'm hoping someone on here has already done this and discovered that it all fits together perfectly, lol.
Old Jun 4, 2015 | 11:10 AM
  #3084
LA_Dog's Avatar
LA_Dog
LOL!!! I have those same conversations in my head each time I'm looking at buying shiny fancy parts. if you try to make sense of it you go nuts.
Old Jun 4, 2015 | 11:14 AM
  #3085
mseymour3's Avatar
mseymour3
I agree wheels are ridiculous. Custom wheels would be nice but I like the OEM breakout wheels. If I ever change wheels it would probably be for the CVO turbine wheels instead of actual custom wheels. And they're around $1000-1200 for a set which is much more reasonable although still expensive.
Michael
Old Jun 4, 2015 | 11:16 AM
  #3086
LA_Dog's Avatar
LA_Dog
It's close enough to where I'd probably give it a try. if you just hold them up and don't actually install them, if it looks too far off you can always return them. you also need to extend the brake line / shifter linkage.
Did you see these kits on ebay from Cyclevision?
http://www.ebay.com/sch/i.html?_from...nsions&_sop=15
Old Jun 4, 2015 | 01:20 PM
  #3087
Pigbacon's Avatar
Pigbacon
I've got a set of those in chrome that I was gonna use but didn't. I could get them to you a little cheaper.
Old Jun 4, 2015 | 03:01 PM
  #3088
snappyfish's Avatar
snappyfish
https://www.youtube.com/watch?v=rXCNdA7F2SE
Old Jun 4, 2015 | 03:30 PM
  #3089
24v's Avatar
24v
Originally Posted by Da-Rza 21
is the handlebar mounting surface 1 inch on our breakouts?...or is it 1 1/8?
1 1/4" or 1.25"
Old Jun 4, 2015 | 03:31 PM
  #3090
24v's Avatar
24v
Originally Posted by snappyfish
Beautiful bike, all it needs is a flush mount front axle.
