Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Sep 16, 2015 | 09:01 PM
  #3671
fj1200's Avatar
fj1200
Originally Posted by MarkFXSTC
Like the tall bars. Not had my BO long but now finding the lean forward riding position a bit harsh on my back. Trouble is I love the look of the bars. Anyone gone with taller risers? Do they help?
1.5 inch risers work with the stock cables and for me brought the bars up and back enough to make the ride comfortable
Old Sep 18, 2015 | 01:50 PM
  #3672
zz2h33's Avatar
zz2h33
Me too. Got them off ebay for around $40 if I remember correctly. 10 minute install. I'm 5'5" and it helped a lot. Search breakout riser spacers on ebay and you'll find them. Come in 1.5 and 2.0"
Old Sep 18, 2015 | 08:54 PM
  #3673
rwoolworth1's Avatar
rwoolworth1
Hey can you tell me what risers you are using with those bars? I just got my BO and the drag bars are not going to work for me. But apes on the stock risers would look horrible IMO. I've searched some threads with people complaining about not being able to find risers that work with the speedo mount, but they were old threads. Can someone tell me if there is something available now that work?
Thanks!!
Old Sep 18, 2015 | 09:11 PM
  #3674
fj1200's Avatar
fj1200
Thanks!!
These are the ones that I use
http://www.ebay.com/itm/Harley-David...item2ca1bb6538
The seller also has them in chrome
Old Sep 18, 2015 | 09:17 PM
  #3675
rwoolworth1
Thanks for the response FJ!
I was actually looking for shorter risers. I want to put apes on but I don't want the tall risers as I think they look funny with apes.
Old Sep 19, 2015 | 05:39 AM
  #3676
HKMark23's Avatar
HKMark23
Thanks!!
Consider the 10 degree riser bushings that are available through Dennis Kirk. You may well find ways to use them that will help solve your problem.
In order to gain riding comfort while reducing the visual impact of apes, I installed 14" apes on short CVO risers and did a 3" tank lift using a DK Custom kit (see my Avatar). To accomplish this, I mounted the risers on 10 degree bushings, angled forward, so the speedo housing clears my tank.
I'm not necessarily suggesting you go through all that, (you'd need new cables too and the exercise is quite expensive), but do consider those 10 degree bushings (85 bux or so) as you think through your solutions.
Old Sep 19, 2015 | 06:00 PM
  #3677
HKMark23's Avatar
HKMark23
Been awhile since I posted pics, (except for above ). Here goes:
A 250 rear tire, Lollipop baffles, chromed Blackline dash, 3" tank lift, heel-toe shifter and a swapped out tank badge are some of the mods you can see. A 204 cam (and SE Supertune) are mods you can't see. FWIW I'm running Red Line products in all 3 holes through a PurePower permanent 22 micron (Absolute) filter. Thats about it, thanx for watching .
Old Sep 20, 2015 | 05:06 PM
  #3678
rwoolworth1
Thanks for the info HK! Now can you tell me where I can buy a set of the CVO risers? I can't seem to find them from Harley?
Thanks again for the help!
Old Sep 20, 2015 | 05:29 PM
  #3679
24v's Avatar
24v
Here you go.
http://breakoutowners.forumotion.com...s-part-numbers
Old Sep 20, 2015 | 05:37 PM
  #3680
HKMark23's Avatar
HKMark23
These are the bushings for sure:
https://www.denniskirk.com/la-choppe...prd/598833.sku
My risers were installed by my dealer who also supplied the bars and cables. Something like this may work but you'd have to E-mail Dennis Kirk for measurements to see if the lower sections of the risers would be compatible with the BO top section.
https://www.denniskirk.com/drag-spec...prd/597171.sku
To clarify, I had the dealer install the 1 1/2" apes with cables and CVO risers and then I installed the bushings later to accommodate speedo / tank clearance with the 3" tank lift.
