Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Sep 14, 2015 | 07:57 AM
  #3661
sothai's Avatar
sothai
Default Primo Rivera fitted!
Finally got around to fitting the Primo LED headlight and am very pleased indeed.
Anyone know what the expected life is of these kind of lights?
Clearly, if it goes, the whole thing needs replacing - is the HD Haymaker similarly redundant?
Old Sep 14, 2015 | 08:04 AM
  #3662
Lindosan's Avatar
Lindosan
Originally Posted by MarkFXSTC
I bought mine with stage 1 already installed. Got the V & A re-map box, V & A short shots and larger air filter under the stock air box which I swapped for a screaming eagle big sucker. When I changed the filter I tried remapping the bike but could only find one for big radius pipes. V & A told me to use this map. I also auto-tuned the bike for about 100 miles and flashed the resulting map. It doesn't run any different to when I got it and still bangs and pops on the overrun. Interestingly V & A commented that they could eliminate the popping but the bike wouldn't run properly! Must what you're getting.
Yes, I also tried to autotune it, and its not running well at all......and the bike is getting burning hot 165c when idling.
I really start to think that the fuelpak doesnt work for intl. bikes
Old Sep 14, 2015 | 09:32 AM
  #3663
Bikerjohn44's Avatar
Bikerjohn44
Stage IV
Default Tune
V H fuel pak suck s e is way better I had no issues on my fat boy lo with the se now with the bo bike runs like ****
Old Sep 14, 2015 | 06:49 PM
  #3664
Bikerjohn44
Stage IV
Originally Posted by TrqUSMC
Been reading this thread for a couple of months and just wanted to introduce myself and my lady.
Here's mine
Old Sep 14, 2015 | 06:53 PM
  #3665
Bikerjohn44
Stage IV
Originally Posted by Bikerjohn44
Here's mine
Old Sep 14, 2015 | 10:33 PM
  #3666
Lindosan's Avatar
Lindosan
Apes from NYC
LAC
Old Sep 16, 2015 | 05:55 PM
  #3667
MarkFXSTC's Avatar
MarkFXSTC
Default The Everything Breakout Thread
Like the tall bars. Not had my BO long but now finding the lean forward riding position a bit harsh on my back. Trouble is I love the look of the bars. Anyone gone with taller risers? Do they help?
Old Sep 16, 2015 | 06:29 PM
  #3668
Da-Rza 21's Avatar
Da-Rza 21
i know what your feeling,that lean forward was a bit much for me,but most of it is the stock seat way to wide in the front and too much foam in the middle,have a new seat being made by my friend sid chavers that does alot of my hot rod builds interior hes reshaping,adding a thin layer of memory foam and re-covering as well...anxious to see what it turns out like,as for bars you need to find a happy medium,thats why i went with the trask bars and what a difference they made without changing any cables,or risers
Old Sep 16, 2015 | 08:50 PM
  #3669
HenryT's Avatar
HenryT
The HD Sundowner seat will place you closer to the bars. It has more padding and is wider...a bit less sleek looking but an awesome long distance saddle.
Old Sep 16, 2015 | 08:57 PM
  #3670
sothai's Avatar
sothai
Danny Gray Reduced Reach is good as long as you don't want a pillion.
Alternatively, the HD Beachbars do the trick without changing the saddle.
