Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jul 10, 2016 | 07:37 PM
  #4941
Duke 13's Avatar
Duke 13
[QUOTE=tphykitt;15307100]Ill have to look those up! Thank you
Originally Posted by HKMark23
Have you considered a tank lift ? Its cheap and relatively easy to do. The mod would include apes, I assume, and there are various ways you can get the speedo to clear the tank, allowing for the lift.
Hmmm, i have not. Is the tank lift displayed in your picture? I don't want really high apes. Just a little more pull back.
I was corrected on the diameter of the fork tubes on the Breakout. They are actually 49 mm but there are some listed on eBay to fit it.
Old Jul 10, 2016 | 10:46 PM
  #4942
HenryT's Avatar
HenryT
[QUOTE=Duke 13;15314153]
I was corrected on the diameter of the fork tubes on the Breakout. They are actually 41 mm but there are some listed on eBay to fit it.
Nahh they are 49mm. This is so silly...who "corrected" you?
Old Jul 11, 2016 | 12:13 AM
  #4943
HKMark23's Avatar
HKMark23
[QUOTE=HenryT;15314701]
Recently completed a Ricor suspension upgrade on my ride. The 2014 FXSB is certainly 49 mm. That I can confirm.
Old Jul 11, 2016 | 11:29 PM
  #4944
Duke 13's Avatar
Duke 13
I would say but not going to make any enemies. I changed my post per your reply.
Thanks Henry!
Old Jul 12, 2016 | 07:31 PM
  #4945
ChromeSpark's Avatar
ChromeSpark
Originally Posted by asputin
Anyone having trouble with hot starts? the last couple weekends on 200+ mile rides,after a stop for fuel or whatever,mine wont turn over.almost like the battery is low.ill let off starter,give it a second,hit it again and it fires up...
If you are having this problem still, have the auto compression setting checked. Found mine was disabled (off) had the same symptoms. Service at dealer didn't even know it had it
Old Jul 13, 2016 | 01:58 AM
  #4946
Nostradamus74's Avatar
Nostradamus74
Some SE maps downloaded via SEPST have ACR disabled and dealers often don't pay attention to this setting. Probably these maps are used both for 96" and 103" engines and since 96" doesn't have ACR that's the reason why it's disabled. On 103" ACR enabled is even more important if you have a stage I,II etc. since it helps starting the bike up. What ChromeSpark correctly said might be the problem or at least part of it.
Old Jul 13, 2016 | 10:19 PM
  #4947
Ink83's Avatar
Ink83
Anyone wanting a custom fabracted steel front spoiler?
Old Jul 14, 2016 | 12:50 AM
  #4948
blacklander48's Avatar
blacklander48
looks great!whats the damage?
Old Jul 14, 2016 | 01:00 AM
  #4949
EagleRay's Avatar
EagleRay
Will it fit an ABS equipped bike, too? The brake line routing on ABS bikes goes along the frame tubes....
Old Jul 14, 2016 | 01:16 AM
  #4950
Nostradamus74
Same question I'd have put...and I'd add the horn mount...
