Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Sep 10, 2016 | 03:16 PM
  #5091
firecap's Avatar
firecap
6th Gear
Originally Posted by JimGnitecki
You have identified ONE of TWO part number questions.
The SECOND question is which international version of the Breakout is a given part intended to be on?
Simple examples of Breakout variances by country:
- The final drive pulley on Japanese Breakouts has a different number of teeth than the U.S. pulley
- The twin taillight configuration of the U.S. Breakout is illegal in Canada. Canada requires both a centrally mounted taillight and a license plate mounted right under it.
Jim G
this is the part # for the service manual i just thought the BR designation might stand for breakout but didnt know found them on surdyke may shoot them an email
Old Sep 10, 2016 | 03:23 PM
  #5092
BreakoutBoy13's Avatar
BreakoutBoy13
Stage II
Originally Posted by NSR
Yep, H-D wheels ... had the black finish stripped off, then polish the edges. Then powder coated the hub and spokes black and cleared the polished parts of the rims. I copied some other dudes bike I saw on this forum somewhere....
Thanks heaps for the reply much appreciated
Old Sep 10, 2016 | 03:41 PM
  #5093
riknbeth's Avatar
riknbeth
I have to agree. The pulley swap makes an immediate, very substnaital change in the performance of the bike, well beyond what a mild cam by itself will get you. This is especially notable at low rpm, where the gearing change effect is VERY noticeable.
Jim G
Jim G. I will apologize right up front, just in case this is a dumb question. By doing the pulley swap does it make the bike go slower at the top end. Meaning right now I got my bike up to 115mph and it was still pulling. With different pulleys I would imagine the bike might only go 110mph? Not that I need to go that that fast, but I was just wondering? I also saw somewhere that the Speedometer needs re-calibration after this work and a new belt?
Old Sep 11, 2016 | 07:11 AM
  #5094
JimGnitecki's Avatar
JimGnitecki
HD bikes these days are geared so numerically low, for noise compliance testing reasons, that increasing the numerical ratio overall, like we are doing, actually gives them a higher top speed.
A new belt is normally NOT needed. You need to read LA-Dog's summary of the regearing process on the first couple of postings in the gearing thread _ I am not going to re-write it here for you.
The speedometer gets recalibrated via a change to the computer's "gearing factor". Again, read the thread summary. We cannot re-write the entire thread for everyone who asks because they have not read the thread summary. LA_Dog has done a GREAT job of both summarizing it and keeping it current as new info is discovered. Read the summary.
Jim G
Old Sep 11, 2016 | 07:59 AM
  #5095
riknbeth's Avatar
riknbeth
Jim G
Thanks for the quick reply and pointing me in the right direction. Reading these posts now. The light went off in my tiny brain when you said increasing the numerical ratio overall. Because you are doing both gears the whole thing is changing. Now I get it. Hats off to you guys for keeping us straight.
Old Sep 11, 2016 | 08:45 AM
  #5096
HKMark23's Avatar
HKMark23
32t compensator kit vs the 30t transmission pulley; which ultimately is the best solution ?
Thanx
Old Sep 11, 2016 | 08:59 AM
  #5097
JimGnitecki
Thanx
Your question is based on doing only a "partial solution".
Changing ONLY the transmission output pulley or the compensator sprocket gives you only a 6.7% overall gearing ratio improvement.
But to answer your question directly, I found that the compensator sprocket change kit, at least at the time a few months ago, was NOT a fit for the Breakout. The Breakout has a unique offset shared only with the Rocker, and the comp kit was not designed for that application.
Note also that the LABOR for changing the transmission output pulley is far more extensive and less DUI-friendly than changing the rear wheel pulley. And if you pick one of the HD rear pulleys that LA_Dog has determined will fit the Breakout wheel, the cost of the rear pulley is not THAT much more than that of the Trike transmission output pulley.
No point in your trying to reinvent the wheel. LA_Dog has compared the alternatives and his summary posting in the gearing thread gives you all the comparative info you need to make a decision.
Jim G
Old Sep 12, 2016 | 07:47 AM
  #5098
HKMark23's Avatar
HKMark23
I Have LA's sheet. It deals with converting BO's with 32t transmission pulley and 66t rear pulley and 133t belt.
My 2014 BO has a 32t transmission pulley, a 64t rear pulley and 132t belt.
Anyone done a conversion on a 2014 BO ? I'm wondering if in changing only the rear pulley to a 68t unit or, the rear to 68t and the transmission to a 30t, if I can retain the 132t belt.
Apologies for dragging this out, but I'm facing Canadian pricing and trying to determine what I'm in for cost-wise.
Old Sep 12, 2016 | 08:05 AM
  #5099
NSR's Avatar
NSR
My Breakout is a '14. I swapped over to the 68T Sportster pulley...last year I think?? Seems like it anyhow, lol... anyway, that's all I've changed with respect to the primary & final drives. The original belt worked, no problem. Plenty of room left for belt adjustment down the road if necessary. The bike has a 250 rear tire now - the Elite 3 Dunlop. Plenty of clearance there as well.
Old Sep 12, 2016 | 05:02 PM
  #5100
HKMark23's Avatar
HKMark23
Thanx Bro !
Just bought this:
http://www.ebay.com/itm/112133686426
Figured I'd risk 100 bux in hopes of saving 400 or 500. Hopefully this will fit.
