• Customizing you bike
• Seats
• Risers
• And much more!
I have put quite a few miles on the new 57H cams, tuned it in very well with the PV TT system. All in all it runs great except it is a bit weaker down low than I would like and I notice it more now with 2-up riding. I would attribute this to the lower static and dynamic compression of thee cams- it is 181CCP with the 57H cams @ 38deg IVC and 9.04:1 dynamic comp.
Stock cams, compression ratio was higher at 187ccp (@ 30deg IVC) - dynamic comp was 9.30:1 - Although the 57H gives long duration and greater lift, the reduction in compression and later IVC event is taking more notice with my riding style (mostly town, a lot of stop / go).
So I have two choices to consider- Keep the 57h cams, pop the heads and run a thinner HG to raise comp - or - drop in a set of 48H cams (29deg IVC). Either will get me to 188CCP and 9.33:1 dynamic. Essentially back to stock comp levels but with better lift & duration. Actually with prices of the 48H cams so low, it looks like the cheapest option.
We all put in a lot of last minute upgrade work before the weather got good- it's nice to be out riding and enjoying our efforts
So how is a normal person supposed to figure out the differences between the different cam offerings and how they will perform? I get the duration and lift differences, and know that I don't need absolute top end performance in my life anymore and just want grunt in the meat of the power band.
I'm looking at the Andrews 48H, Woods 333, and the SE 204's. I know that S&S also makes cams but for some reason they don't seem widely used. So will the cams I listed all pretty much ride the same?
I'm doing the 30/70 upgrade before the cams, but it seems like there are great deals on the cam sets at the moment and figure that's a great with the project.
Well, I can vouch for this. My brother has a '14 CVO breakout. 2-2 big radius with SEPT. I have a '14 breakout, short-shots, SE-AC, FP3 and 204 cams. Rolling start at about 60 mph, he pulls away slowly at first. But, when I get farther into the RPMs I walk past him. 204s give me more hp-tq through most of the RPMs. The 255s he has are all low RPM tq.
With that being said, get cams for how you ride. I love my 204s because they work great at cruising speed, even 2-up for me and give me great performance if I want to open her up. It's the best of both worlds.
Consider 555s or even 777s if you go with Woods too. A lot of people have put 204s on breakouts and love them.
"Seems to work for me".
I think most people that come from a background of 4-wheeler/dirt bike/sport bike riding will prefer the tq/hp in the mid-high RPM range. Mostly because that type of riding style uses a lot of shifting. I don't mind shifting gears. Then again, I'm just used to it. This is why you hear "get the cam for your riding style" when people ask about cam choices.
But honestly- no BS here - just do the 30/70 pulley upgrade, tune your bike with a good timing table and fuel map, and I don't think you'll care about spending the money on cams right now. Pulley upgrade = big difference, mild cam upgrade = small difference. your next big difference would be cams combined with headwork, raise compression, increase CC to 107, etc.
All I'm sayin is keep it simple and one step at a time- there will always be deals on cams floating around- do the pulleys and a good tune- go ride - see where you are at. you'll be stoked.
Jim G
