• Customizing you bike
• Seats
• Risers
• And much more!
- Spin the engine to a higher rpm, which our large displacement V-twins are not really eager to do without some issues
- Supercharge it or turbocharge it, which has the advantage of adding power everywhere in the rpm range
- Increase displacement, which makes the already large displacement V-twin engine even less happy about high rpm operation, and and which can affect the vibration level a notable amount
All 3mthods "pull in more air" per minute and "return more power".
All 3 methods stress that press-fit crank, but the first method stresses it the least, since it focuses on making the same or only marginally larger torque but doing it more times per minute. A welded crank is a good idea if using the 2nd and 3rd methods.
The second method makes more power than either the 1st or 3rd, but is a bit complex and usually leaves some ugly hardware exposed that sits where you want your leg to be.
If you want a racy sound and feel along with the power, the first method usually does that the best.
And, if what you REALLY want is simply snappier acceleration and throttle response, just regerar the Breakout from 32T front pulley and 66T rear pulley to 30T front and 70T rear. Guaranteed to make your bike a LOT livelier!! (see LA_Dog's sticky thread in this Softtail section of the forum). And, it will only cost you a few hundred dollars. Bargain of the decade as far as "going faster'.
Jim G
For motor upgrade I'd do a set of cams first. that combined with the gearing will probably be all you need. We're talking $1500 area to do both pulleys and cams, and make quite a difference combined with good tuning. that's a lot of bang for the buck.
if you want to just go big- hell nothin' wrong with that- get one of the FM, hillside cycle, zippers 107 kits. it is extremely important to match all components when building up a motor. these places have already done the hard work for you and you just buy the kit. You'll have better than 110hp/115tq with the right kit and tune. Let's say $3k range with labor costs and tuning, and not including cost of the pulley upgrades ($900 range). very good upgrade but maybe not as big of bang for buck. really depends how much you want to spend and how much pow-pow you want under ya. On the upside, your 2016 BO already has 4.3 injectors and 50mm TB, so you can reuse that with the 107 kit and it will work fine. those of us with the smaller TB and 3.9 injectors would need to go bigger to support over 100hp.
I think it has the correct dimension to fill a bit the gap between frame and front wheel without being bulky, it has the exact hole for the voltage regulator and complements well the overall look of the bike.
Here are some pics.
Here are some pics.
the injectors are the SE 4.9 injectors. surdyke.com usually has best price on the 2-injector kit. I'll look around for ya. about $130 for the pair. you definitely need, without a doubt, larger injectors and a 50mm TB. you'll have a **** poor time trying to tune it with the small 3.9 injectors and they do not support any more than 100hp tops. you can go larger like 54 / 58mm on the TB but you then need to design the motor accordingly. larger TB usually leads to lower intake velocity and reduced low end TQ. you do gain top end HP but on a street bike you have to pick the happy medium. I'd prefer more tq at low / mid than top hp.
BTW got bike fired up this evening - sounds like a beast now. that 50mm made a bit of good difference indeed. tomorrow is test ride and tuning.
