Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Apr 23, 2014 | 05:44 PM
  #561
HKMark23's Avatar
HKMark23
Originally Posted by 24v
Bar change is not required to do a tank lift, just riser spacers.
My bar change had already been done before I did my lift so I didn't know this would work with stock bars for sure, horizontal on the apes being narrower of course. That said, I'm not surprised. The riser bushings are about 85 bux as I recall and are a very easy install. Obviously though, if you keep stock risers and bars, the bushings will increase your reach by as much as a couple of inches I would think.
It might be an interesting experiment to reverse the stock risers and use the 10 degree bushings to slant em back toward the rider. I have no Idea how well, or if this would work but maybe the combination would give tank clearance without extending the reach or screwing up the presentation angle of the gauge. Someone's gotta try it so we know .
Old Apr 23, 2014 | 06:33 PM
  #562
24v's Avatar
24v
It will work with the stock bars. I've seen pictures of it done.
Old Apr 23, 2014 | 09:22 PM
  #563
poonplatoon's Avatar
poonplatoon
good idea with the riser spacers. But, it will not work with the stock set up. I tried.
Old Apr 23, 2014 | 09:43 PM
  #564
24v's Avatar
24v
Except it will.
Old Apr 23, 2014 | 09:47 PM
  #565
24v's Avatar
24v
Here are some more pics.
Old Apr 23, 2014 | 09:58 PM
  #566
Harley_Charley's Avatar
Harley_Charley
I think the reason it works is because he rotated the bars upward. If you look at the pics the handle grips are pointing towards the sky vice horizontal.
Old Apr 23, 2014 | 10:21 PM
  #567
poonplatoon
And he used riser spacers. You can clearly see them. Trust me you can not do it with the stock set up. Again I tried it.
Old Apr 24, 2014 | 06:06 AM
  #568
24v's Avatar
24v
For the tank lift you must change your bars, or when fully torqued they hit the tank.
Bar change is not required to do a tank lift, just riser sapcers.
I said from the beginning it required spacers?
Old Apr 24, 2014 | 09:54 AM
  #569
poonplatoon
Hence why I said good Idea with the spacers. And then I said it can not be done with the stock set up. Then you said "except it will". But, it can not.
Old Apr 24, 2014 | 10:00 AM
  #570
NSR's Avatar
NSR
Looks like he also flipped the speedo.
