Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Aug 28, 2017 | 09:08 AM
  #5891
cdonis's Avatar
cdonis
Originally Posted by splattttttt
ot sure if you done it, but have you swapped out your final front and rear pulluy's?
Betting that set up there could get you close to a 10 sec. finish at a drag
No I haven't. I rode it to work this morning and seriously doubt I'll need it. This motor has some grunt, that's obvious already. I'm not one that worries about 2000 rpm tq. When leaving the line that's a non issue, and when rolling I prefer to stay in the correct gear. I could be wrong and a pulley swap is not off the table. Btw, had a guy already wanted to run his dyna against " That" softail.
Old Aug 28, 2017 | 09:45 AM
  #5892
splattttttt's Avatar
splattttttt
Haha, same motor. You know his build?
Your cams are more for top end or low torque?
If the build was mostly for top end, then a rear and front pulley swap would make for takin off the line way quiker with out hurting top end
Old Aug 28, 2017 | 10:48 AM
  #5893
Jessica Sinclair's Avatar
Jessica Sinclair
Could someone confirm if the Breakout CVO Pro Street seats will fit a normal 2017 Breakout?
Old Aug 28, 2017 | 11:14 AM
  #5894
cdonis's Avatar
cdonis
Mid to top. I'm sure this motor will have every bit of low end my stage 2 103 had and more across the board. As far as the dyna guy, he is a young local club member who's mouth is bigger than his bank account. He lost interest fairly early in the conversation.
Old Aug 28, 2017 | 11:21 AM
  #5895
EagleRay's Avatar
EagleRay
Jessica, I thought we discussed this before and had everything sorted out.....hmmmh.....why don't you stop by your dealer and try......a chat with rhe parts guy over there might also answer your question
Old Aug 28, 2017 | 01:47 PM
  #5896
Odinbreakout9's Avatar
Odinbreakout9
They will definitely fit! I almost went that route (hated sliding on the seat)... then picked up the Fred Kodlin seat by Mustang. Love it!!
Old Aug 28, 2017 | 02:47 PM
  #5897
Jessica Sinclair
https://www.revzilla.com/motorcycle/...kout-2013-2017
$450 is pretty steep for a solo seat
Old Aug 28, 2017 | 03:43 PM
  #5898
Odinbreakout9
Says the gal with a stage 5 lol.. I get it tho
Old Aug 28, 2017 | 05:39 PM
  #5899
JimGnitecki's Avatar
JimGnitecki
But fine value compared to what you pay for what you get when you buy an HD accessory seat! Take a look at the underside of your HD seat, and then look at a quality aftermarket seat!
Jim G
Old Aug 28, 2017 | 05:45 PM
  #5900
indobos72's Avatar
indobos72
Jessica,
Here is what I chose for a solo seat. I had the same problem with sliding out the seat. This is a comfortable option for a $100 cheaper. Unless you add some of the air or gel cushion options. This is the one I went with and it feels great and keeps your seat planted when cracking the throttle hard.
https://www.revzilla.com/motorcycle/...kout-2013-2016
