Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 4, 2014 | 06:49 PM
  #621
Msmall's Avatar
Msmall
Pc stuff back. I have black strut bolts on order.
Old May 4, 2014 | 06:50 PM
  #622
Msmall's Avatar
Msmall
Rear signals
Old May 4, 2014 | 06:52 PM
  #623
Msmall's Avatar
Msmall
Tank trim. I have a black flush mount gas cap on order
Old May 4, 2014 | 06:53 PM
  #624
Msmall's Avatar
Msmall
Seat bolts
Old May 4, 2014 | 11:43 PM
  #625
cdonis's Avatar
cdonis
Originally Posted by gasilla
I like the look of this faring but when I called Memphis shades they said they did not yet have a mounting kit for the breakout, are you happy with how yours is mounted?
I have the bullet fairing and they do have breakout specific mounting hardware. Looks killer and fit good too. No problems at all, 15 minute job.
Old May 5, 2014 | 01:38 PM
  #626
txgent73's Avatar
txgent73
I ordered and Installed a Custom Dynamics LED to replace the silly rear reflector
removed the rear fender
Loosened the struts from the fender, but did not remove them yet.
slid packing tape under the rear of the strut and traced the outline of the strut on the tape.
removed struts from fender
used the inner fender and lined it up with the holes on the outside of the fender and marked on the tape where it came. Also I eyeballed the inner line that represents the thickness of the lip on the strut, and eyeballed the placement of the hole to be drilled.
Drilled hole in fender (kind of hurt my heart to drill in a fender so new, but it is all for the mods)
used the supplied 3m adhesive promoter on bottom of fender and stuck the LED in place. I think i placed it to far back and am still deciding if I like it there or if I should move it further toward the rear lip of the fender.
ran the wires through the hole I drilled then through the strut.
did the same think on the other side, but it was a bit more difficult due to the wiring for the license plate light also being there.
put the strut back on fender and pulled wires to take up the excess from under the strut.
wired to bike and put it all back together.
Now I ask for opinions. Should I leave it back that far in the fender, so that it only puts off the glow on the tire and behind the bike, or should I move the LED closer to the rear of the fender so that the LEDs can actually be seen from behind me.
Also I want to make the light a dual function Running/Brake light, but could not find a wire that was just brake. Does anyone have a wiring diagram of the Breakout?
Old May 5, 2014 | 02:45 PM
  #627
JimGnitecki's Avatar
JimGnitecki
All I see in that last photo is "a glow" on the tire, no real light. I think you should move the LEDs much closer to the lip of the fender, as a safety issue. That "glow" will be of very little value in rainy or foggy conditions, and on a regular starry night, a following driver won't see it until VERY close to hitting you.
Jim G
Old May 5, 2014 | 05:17 PM
  #628
24v's Avatar
24v
The unused space in the tail light connectors has a brake wire on the other side.
Old May 5, 2014 | 05:37 PM
  #629
asputin's Avatar
asputin
I think you should bring it back closer to edge of fender,see it much better
Attached Thumbnails The Everything Breakout Thread-538.jpg   The Everything Breakout Thread-535.jpg
Old May 5, 2014 | 11:00 PM
  #630
Wotto's Avatar
Wotto
6th Gear
For what it's worth im with the other fella's, move it back.......
