Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jun 17, 2014 | 04:02 PM
  #811
Msmall's Avatar
Msmall
Ironing out a couple issues but finally got my sissy bar on the bike
Old Jun 17, 2014 | 04:04 PM
  #812
Msmall's Avatar
Msmall
Anothet
Old Jun 17, 2014 | 04:05 PM
  #813
Msmall's Avatar
Msmall
Without pad
Old Jun 17, 2014 | 04:06 PM
  #814
Msmall's Avatar
Msmall
Last with pad
Old Jun 17, 2014 | 04:44 PM
  #815
txgent73's Avatar
txgent73
is that a Ginz bar? and what size pad is that?
Old Jun 17, 2014 | 04:58 PM
  #816
Msmall's Avatar
Msmall
Yes, 12 inch pad but I wanted the fury style. What do you think?
Old Jun 17, 2014 | 05:24 PM
  #817
dmac936's Avatar
dmac936
6th Gear
Default New Exhaust
Finally got my Vance and Hines Big Shots Staggered on. However, I have an exhaust leak at the flange. I used the gaskets supplied with the exhaust and tightened the flange nuts down evenly to 15 ft. lbs. and retorqued after heat cycle. I'm thinking about replacing the gaskets with the stock gaskets, but was wondering if anyone had any advice. It's a rather small leak from both pipes, but I am having a lot of decel popping (no A/C or tuner yet). Here's a pic cuz I know you guys want to see.
Old Jun 17, 2014 | 05:46 PM
  #818
24v's Avatar
24v
Are you basing the leak on decel pop, or have you actually tested to find the leak?
Old Jun 17, 2014 | 06:22 PM
  #819
Msmall's Avatar
Msmall
+1 why you think you have an exhaust leak?
Old Jun 17, 2014 | 06:34 PM
  #820
JimGnitecki's Avatar
JimGnitecki
dmac936: Is the torque on the exhaust nuts supposed to be that high? Are you sure? Maybe I'm remembering wrong, but I thought it was more like 8 or 10 ft lb. You sure don't want to strip those studs. THAT would for sure cause a pretty good leak.
Also, use a torque wrench that preferably has a working range that includes the target torque number comfortably within its range. i.e. do not use a 150 ft lb capacity torque wrench and set it to 10 ft lb. The accuracy will be poor that near the bottom of its range.
Jim G
