Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Dec 31, 2014 | 07:12 AM
  #1811
24v's Avatar
24v
Originally Posted by Dean2014
Thanks for the advice 24v, that will save me a lot of hassle not having to drain fuel etc.
Jimstang, will post photos when done and yes the new cables are only couple of inches longer as the original will go very tight on full lock.
Also, be sure to put something, like a piece of cardboard, between the crossover line and the rocker box cover before moving the tank. This will prevent the clamp on the fuel line from scratching the rocker box cover.
Old Dec 31, 2014 | 10:59 AM
  #1812
Jimstang's Avatar
Jimstang
Coolness...yeah I just compared some pictures of the CVO bars compared to the stock drag style bars, and there definitely have more bend than I thought. Always learning!
Hope your install goes well.
Old Jan 1, 2015 | 12:18 PM
  #1813
Dean2014's Avatar
Dean2014
4th Gear
Default Front Upper Brake Line Part Number required for CVO Handle Bars Conversion on FXSB
Guy's,
Hit a snag when I went to fit the new upper brake line to the new CVO handle bar conversion on my FXSB Breakout. The HD OEM Website states that you need part 45829-11 for this (increased length) fitment, however it turned out to be exactly the same length as the standard brake line (Part No. 41800217).
Has anybody out there done the same conversion and ran into this same problem?
Old Jan 1, 2015 | 03:56 PM
  #1814
24v's Avatar
24v
I'm assuming you have ABS. If so, I would bet part number 45856-11 would fix the issue. That is the upper line from a Heritage Softail with ABS. They have taller bars stock.
Old Jan 1, 2015 | 06:35 PM
  #1815
Dean2014's Avatar
Dean2014
4th Gear
Thanks 24v, yes I have ABS (UK), the current length of both the old and new brake pipes are 32" and I figured it needs to have another 4" added. I checked out your part number 45856-11 on partscanada website as they list the lengths and that comes in at 36 1/2", bang on!! Will be ordering that tomorrow, hopefully the dealer will take back the the other pipe especially with HD listing the wrong Bill of Materials for the conversion to the CVO bars
Will post some pictures once it is all done, but even now the the bars look great on the bike.
Old Jan 4, 2015 | 04:53 AM
  #1816
pyrorico's Avatar
pyrorico
Wow... I just read all 185 pages...
Thanks for putting all this info in one spot...
I think I will be sourcing a Blackline dash as one of my next mods...
I have had a 2014 vivid black breakout for nearly a year now...
Old Jan 4, 2015 | 05:34 AM
  #1817
liamw76's Avatar
liamw76
Have been quoted $550aus for the blackline dash conversion. Does this sounds right?
Old Jan 4, 2015 | 07:12 AM
  #1818
24v's Avatar
24v
We pay about 1/2 of that for the parts here.
Old Jan 4, 2015 | 09:49 AM
  #1819
HKMark23's Avatar
HKMark23
To me that sounds like a "good" deal.
Old Jan 5, 2015 | 09:58 AM
  #1820
Msmall's Avatar
Msmall
Sounds nice.
Can you post a full pic of the Dyno printout. It just shows peak which doesn't really tell torque curve.
Also, do you have a pre install dyno sheet printed.
Dyno reading range so much from Dyno tk Dyno. Without the pre/post it's really hard to gauge increases.
Even if you don't have it the tuner may.
Looking forward to seeing what you have. 211 is an interesting choice, cool to see someone doing something different. How did you end up going with the 211. Even Andrews told me it would be a good fit for the 103
Are you planning future modes. Maintained stock conpression? Do you change out lifters?
Originally Posted by youraemoo
Yes they do, I was pretty surprised with the numbers.. I was reading some conversation, heard people were getting between 80 and 85
