Rain storm...won't even crank now!
Old Dec 18, 2013 | 09:54 PM
CharlieJ's Avatar
CharlieJ
6th Gear
Question Rain storm...won't even crank now!
After a torrential rain storm 3 nights ago, my '03 Fat Boy won't start.
There was a slight leak in the canopy - that became a huge leak. Unfortunately, I didn't discover it until the bike was soaked. Now, it won't even crank ("turn over").
At first, the gauge light, headlight, etc wouldn't come on. Took off the battery cables off and cleaned all the battery connections today. I charged the battery, too. It was on 75%... 2 hrs later at 100%. After trying to start several times, it's still at 98%.
Once charged, the gauge light comes on... well, most of the time. If I wiggle the switch, it comes on. The headlight still does not come on. I don't hear the fuel pump cycle either. And, the starter switch and push button start do NOTHING.
PLEASE give me some advice. Is there a good chance I can push start and get it going...or is that not an option without getting to the "cranking" stage?
THANKS!
Old Dec 18, 2013 | 10:02 PM
JustDave13's Avatar
JustDave13
Ouch, you may have to wait until everything drys out, it might be a good idea to disconnect the battery until then.
Old Dec 19, 2013 | 05:11 AM
Blk and Chrome's Avatar
Blk and Chrome
dry it out, a blow dryer may help
Old Dec 19, 2013 | 05:41 AM
QC's Avatar
QC
Sounds like your ignition switch is wet grounded. Agree that the battery should be unhooked til it dries out. Also check the fuse block for water. Don't bother trying to push start it, if the fuel pump isn't turning on, it won't start. I'm pretty sure an electric bike isn't capable of being push started under any circumstance.
Old Dec 19, 2013 | 07:08 AM
Gman in NC's Avatar
Gman in NC
It does sound like water got into the switch. A little heat/air and exercising should do it.
Old Dec 19, 2013 | 07:50 AM
BornTexan's Avatar
BornTexan
Get your leaf blower out and go to town. Concentrate on the switches on the handle bar, the speedo and the headlight light bucket.
o~\o
Old Dec 19, 2013 | 08:29 AM
Damn_Yankee's Avatar
Damn_Yankee
If you can get it into an enclosed area, a dehumidifier should speed up the dry out process.
Old Dec 19, 2013 | 05:32 PM
FroggyFatBoy's Avatar
FroggyFatBoy
pull up the console and tilt it over and see if water runs out of the ignition switch body. if it does, tilt it around till all the water stops coming out then spray some WD-40 in the switch. WD= Water Displacement. its about the best thing for cleaning water out of switches.
Old Dec 19, 2013 | 06:33 PM
tmilo1000's Avatar
tmilo1000
Agreed, it needs to dry out. Had similar problem when washing the bike. Start switch and kill switch got wet, dried them out and everything was good.
I have pushed started an '08 Fat Bob. Not enough juice to crank, but it did start. Stator and voltage regulator went bad. Barely had enough juice to get to town.
Old Dec 19, 2013 | 06:52 PM
73oldsman's Avatar
73oldsman
Once you get everything dried out and running again, go over your bike and disconnect each electrical connector, apply some dielectric grease and reconnect. Should help in the future. I did this to my Fatboy after my first Florida rainstorm and problems. I've been through many more since then and it hasn't missed a beat since.
blackflame
May 22, 2021 09:01 PM
supermanotorious
Mar 23, 2018 12:11 PM
2013superglideseattle
Milwaukee Eight (M8)
35
Feb 28, 2017 06:32 PM
leachman
Feb 25, 2016 04:32 AM
mike06train
Jul 6, 2011 10:36 PM
