I'll try again.... LA Choppers 13inch apes
Old May 10, 2014 | 10:25 AM
07 deluxe's Avatar
07 deluxe
Default I'll try again.... LA Choppers 13inch apes
Does anyone have a set of 13 inch twin peaks apes, not bagger apes? I am in need of some measurements.
Old May 10, 2014 | 02:40 PM
dyolfknip's Avatar
dyolfknip
I have a set of the TreeHugger apes sitting on my shelf waiting for other parts to come in if that helps.
Old May 11, 2014 | 08:24 AM
07 deluxe's Avatar
07 deluxe
withdrawn
Old May 11, 2014 | 08:26 AM
07 deluxe's Avatar
07 deluxe
Default tree huggers
Are they the 13 inch miter cut or the other? The other is what I would be looking at. Your post made me go back and look at the tree hugger offerings . I didn't realize the bars could still be adjusted. They just might work and I can kill two birds sort of speak. I need the exact measurement between the bars at the bottom and then up top, and how high the built in riser is. Thanks
Old May 11, 2014 | 09:15 AM
dyolfknip's Avatar
dyolfknip
Mine are the mitre cut. The riser is .5" it would be the same on the normal ones. Let me know if you want the measurement anyway, but I would guess it is 13" as they are sold as 13.5" bars.
Old May 11, 2014 | 09:25 AM
dyolfknip's Avatar
dyolfknip
So I went and grabbed them.
.5" riser
And here is a so-so measurement to give you an idea of height.
PM me if you need anything else.
Old May 12, 2014 | 07:42 AM
07 deluxe's Avatar
07 deluxe
Default between the bars
Can you measure between the bars at the bottom and then at the top? I need bars wide enough for the radio box to fit in between. Thanks.
Old May 12, 2014 | 11:47 PM
dyolfknip's Avatar
dyolfknip
9" at the bottom, 10" at the top. Both measurements on the inside.
flex58
Jul 18, 2015 10:33 PM
scooper321
Feb 12, 2014 05:30 AM
Jersey_Marine
Aug 7, 2013 03:34 PM
BigGelvis
Jun 13, 2013 04:54 AM
EXAMMO
Sep 9, 2007 12:00 PM
