Slip on pipe install
Old May 17, 2014 | 09:45 PM
rbeamj's Avatar
rbeamj
Default Slip on pipe install
Ok. So I got my new VH pipes in the mail and went to remove the old ones. Talk about a PITA. The clamp on the front muffler would not slide off of the pipe due to the x-over tube.
I think I will have the clamp bolt be at the bottom instead of the inside as originally installed due to the difficulties of access for the future.
Are there any issues with this or should I rotate it as far inward as possible but still allow it to slip forward should the need arise.
14 heritage classic
Old May 17, 2014 | 11:52 PM
sioux565's Avatar
sioux565
On my 13' Slim, the mufflers were a pain to remove. I soaked the original clamps in WD-40 for a few minutes and that made it easier to slide the old mufflers off. Both of my new clamps are rotated to the bottom. Easier access, but they are more visible.
You have nothing to worry about.
Old May 18, 2014 | 09:20 AM
WildBill_50's Avatar
WildBill_50
I have both of mine rotated to the bottom as well on the 09.
Old May 18, 2014 | 06:32 PM
Dutch101st's Avatar
Dutch101st
Mine were not too bad on my '14 Slim...did take a bit to work off but didnt need to soak em.
Old May 18, 2014 | 07:23 PM
sioux565's Avatar
sioux565
I was surprised that my stock mufflers were such a pain to remove as they only had 500 miles on them.
Old May 18, 2014 | 07:55 PM
checkers's Avatar
checkers
14 heritage classic
First, remove the hose clamped pipe heat shields and get them out of your way. Remove front muffler first. When installing, install the rear muffler first and fully tighten clamp on rear muffler, once you install the front muffler, you will not have access to the rear clamp. You can put the clamps on any way you can get to them.
xl8832007
Dec 19, 2012 03:21 PM
TKDKurt
Oct 1, 2011 08:32 AM
jlturner
Apr 4, 2010 06:21 PM
sportster883bob
May 15, 2009 05:10 PM
gilmour68
Feb 20, 2009 08:44 PM
