Carlini Evil apes on '13 Breakout
Old Jun 25, 2014 | 08:18 PM
Sgt Squid's Avatar
Sgt Squid
6th Gear
Default Carlini Evil apes on '13 Breakout
Need some advice on which size to get. A few years back I was involved with a pretty bad work related accident that essentially blew my elbows out of the back of my arms (cringe now)... as a result my range of motion is limited as far as extending my arms. Although I love the look of the Breakout with drags, it simply isn't comfortable for me to ride. My position, with arms fully extended is still slightly hunched over with the stock bars. Looking at several options I like the Carlini Evil Apes http://www.carlinidesign.com/Handleb...gers/Evil-Ape/
My question is, what height would be best for me? I know personal preference comes in, but in general what would you recommend for a 6' 2", 230lb short reached troll? Thanks for your input, Dan.
Old Jun 25, 2014 | 08:26 PM
tbonetony06's Avatar
tbonetony06
It's hard to give advice for something that is so personal to each individual. Having said that and with your size I would suggest the 14" with the 1.5" riser. Good luck and let us know what works out for you.
Old Jun 25, 2014 | 09:35 PM
Iron lHorse's Avatar
Iron lHorse
Simple buy both knowing the one you don't want gets returned. Alway works for me.
Old Jun 26, 2014 | 07:37 AM
24v's Avatar
24v
I'm roughly 5'10" and have 14" Carlini Pist. They are essentially evil apes with the radius going forward instead of back, so the dimensions should be very similar. Keep in mind, I also have CVO risers, which you will likely want. These are about half as tall as the stock risers, and no pullback.
Old Jun 27, 2014 | 01:45 PM
ADRENALINE RUSH's Avatar
ADRENALINE RUSH
^^^ looks good!
Old Jun 27, 2014 | 03:38 PM
elizer's Avatar
elizer
I too have the pist apes. im 6' long dangling monkey arms. I went with the 14" with 1.5 risers. In retrospect I probably should have gotten 16" but these are confortable. Eitherway you can bring the bars in a little closer to you
whovoy580
Sep 23, 2011 09:42 PM
Robertc82
Aug 26, 2010 04:08 PM
royston
Dec 12, 2009 08:35 AM
zetaseven
Feb 21, 2009 06:56 PM
seven7
Mar 1, 2008 07:46 PM
