cheap nonstore bought mods
Total cost around $6.00 it gives me more ride control options , and a great conversation starter.
Just drill and tap holes for 1/8" NPT and you're done.
Hint , they are VERY thick , use a really good drill.
Mick
https://www.hdforums.com/forum/sport...elocation.html
I want to get it down to about 3/8" off the tire. There is enough metal on the brackets that I am going to drill 4 new holes 5/8" higher on the bracket and then trim the extra metal off.
First thing was to get the new holes drilled in the front fender bracket.
Was able to get them 5/8" higher, which is what I was hoping for.
Now time to cut off the extra metal. Not worried about the paint, new paint is coming later.
Trimmed this much off.
Did a little smoothing up and rounding the corners. Better finish will come later, when prepping for paint.
Now time to fit it up.
Here is how it looked stock....riding 1" above the tire.
Here it is mounted with the new holes.
From the side-
Much Better!
DKCustomProducts.com
spring seat bracket:
toying with the idea to put a home made XL 1957 look-alike headlight nacelle on my mid-glide fork, not finalized yet:
Home made rear rack, removed since it cracked, must be repaired:
Looking to finalize the mounting of a set of WL 45" fenders with ditto Beehive taillight, those should get to the painter this year:
That sums it up, I guess...
