Battery problem?
Old Apr 30, 2007 | 12:49 PM
spstrmike's Avatar
spstrmike
Stage III
Default Battery problem?
Hello, Maybe someone can point me in the right direction. This spring, it seems my "04" xl1200c turns over a bit slower than in the past,especially when hot. After a short stop while riding it will not turn over 1 rev. the 2nd try it starts. It was on a battery tender all winter, just performed service( oil, plugs, filters, chain adj.).Did a load test on it- seemed ok. Any suggestions?
Thanks, spstrmike
Old Apr 30, 2007 | 12:51 PM
sleepneagle's Avatar
sleepneagle
Default RE: Battery problem?
check all connections to be clean and tight.
Old Apr 30, 2007 | 02:59 PM
cHarley's Avatar
cHarley
How old is the battery? Max battery life is about 2 years so if that's the case replace it. Part of the problem is the lights ( headlight, tail light etc.) draw close to 8 amps from your 20AH battery as soon as you turn the ignition switch on. It doesn't leave much for the starter especially it the motor is hot.
Old Apr 30, 2007 | 05:03 PM
itsshemp's Avatar
itsshemp
Happens to me all the time. Normally, it wont turn the first try, just let go, try again, and good to go.
I find that if I crack the throttle a tiny bit, it cranks easier. I have the extra lights, so that does not help.
Old May 1, 2007 | 03:40 PM
spstrmike's Avatar
spstrmike
Stage III
Thank you everyone for your input. I purchased a new battery today and the symptomshave goneaway. Thanks again- spstrmike
dinolo24
Nov 14, 2014 09:53 AM
BadMetal705
Dec 23, 2011 02:18 AM
cromagnon
Jan 8, 2011 10:00 PM
Wrongturn
Jun 8, 2009 03:27 PM
scooterhead
Ironhead
Apr 8, 2008 04:36 PM
