power vision tuner
Just got my PV but I hadn't realised it didn't come with a bar mount. I have an ultimate addons GPS case which it will go in but there are clearly better mounts out there. What do you guys use as i get zero returns on a UK ebay search?
Am I right in thinking this is a standard 4 hole AMPS mount?
Thanks
I decided to upload the Dynojet map for my Iron fitted with SE air filter and V&H short shots. This was just to see how it felt compared to the HD SE Stage 1 tune. So I flashed it to the ECU and thought I'd ride across London where the bike would get up to full working temperature and then enable the autotune.
I started the bike up and immediately noticed the DJ map was different. My bike spluttered a bit when I pulled out of the car park and the bike just felt vague coming off idle as I fed the throttle in. A few more splutters on pull away as I rode down the first few streets but as it warmed up it felt the same, albeit with a slower, lumpier idle?
I finally got across London and enabled autotune. I then rode home in a fairly heavy traffic but got some good varying and constant throttle openings. I then hit some open roads for some wider throttle openings and throttle roll on and offs. I guess it was about an hour in total before I stopped and saved the tune and flashed the new, improved map to the ECU.
The difference is noticeable from pull away. Much cleaner, linear spread of power. Much better throttle response and it even feels quite, well, aggressive when you give it a handful!! Part throttle cruising at low speeds is pretty much faultless and the bike just feels a lot smoother overall.
For those that are interested in such things, below is the table showing the VE cells. I'm not quite sure how to interpret it just yet but i'm guessing the red cells aren't a good thing?
